after priming the boot lid on friday i thought i might show you how to rub out a paint run. in this picture i spray three wet coats within a minute, not long after the 90cm run appeared
to repair this paint run properly you must let it dry thoroughly. i gave this about 12 hours. to keep an eye on the repair wotk i gave it a quick s[pray with the gloss black paint
next step. out with the 320 wet/dry sanpaper. bowl of water with a few drops of dish washing detergent and a couple of minutes later i was over half way through the rub out. this was a pretty bad run as the photo shows
paint run has been completely rubbed out and first coat of primer applied
final coat of primer and the paint repair completed. all it needs now is a rub back with 600 wet/dry and on with the top coat.
from start to the finish. total time about 30 minutes. plan to paint it on monday
hopefully this little exercise might help some-one in trouble out. paint runs can and do happen so be prepared.
