david_syd_au wrote:gslender wrote:Nice idea. The HSDs have a cam face, and you attach a collar button with thumb screw to secure it. Adapting this to a simple solid cable/rod system would be the go!!
G
I sent a query about YSR remote adjuster cables to MX5 Mania, and they advised yesterday that YSR are providing a set to trial in my car.
David & AJ were not sure if these are an existing part that YSR have for some other application and that they suggest will work for an MX5, or whether they are a newly designed part.
They should be here in a week or so, and I will report then on how they work.
If they seem ok, I will also ask MX5 Mania about what the supply arrangements will be for past and future YSR users.
Adjusters have arrived
They screw onto the top of the rear YSR shocks in the boot of my NC.
They appear to be long enough to extend past the plastic paneling into the boot, but I can't for sure until I replace that paneling on the weekend.
When using the extended adjuster, it is not as easy to feel the 'clicks' as when using an adjuster directly in the top of the shock, but still can feel them ok.
MX5 Mania is not sure whether these will be supplied with future shock orders, or whether they will be an optional extra.
They reckon the extended adjusters should work for the rear shocks in both NCs and NBs, but for NAs the spare tyre would block access to the right shock.
