Toyota Coil Over Plug Ignition Results
Re: Toyota Coil Over Plug Ignition Results
Postby NitroDann » Tue Jun 28, 2011 12:25 pm
when i can get near a computer rather than my phone, ill post all the photos. I actually used only the toyota loom with no extending wires or anything, just pulled it totally apart, followed the wires i needed, then cut them all the way back at the computer plugs.
To answer your question though, yeah I gutted the igniter, the best part about this is that I can plug my cops onto ANY 1.6 setup to show people the difference on their own car, in under 2 minutes. I even used the stock toyota loom holding clips and it looks great.
jerrah
Postby jerrah » Tue Jun 28, 2011 2:40 pm
I'd like to gut a ignitor but I'd like to have a spare in case I need to run the old system. People seem to want a significant amount of money for them though!
1991 MX5
mx5gem
Postby mx5gem » Thu Sep 08, 2011 4:34 pm
When moving from the puny OEM coil packs to the Toyota COPs, does the more complete combustion lean out the mixture and require any subtle fattening of the fuel table to compensate? (assuming aftermarket ecu)
(Apologies for the same posting in two threads, but wasnt sure which one was best.)
Si.G
Postby Si.G » Fri Sep 09, 2011 10:07 pm
mx5gem wrote:When moving from the puny OEM coil packs to the Toyota COPs, does the more complete combustion lean out the mixture and require any subtle fattening of the fuel table to compensate? (assuming aftermarket ecu)
I have not had to change my WOT map, but idle and cruise needed a small amount of change, was not so far out that it would cause an issue though.
Si.
NA6 B6T
Barbagallo Raceway : Long Track 67.394, Short Track 56.755
mx5gem
Postby mx5gem » Sat Sep 10, 2011 10:38 am
Thanks for the clarification.
rascal
Postby rascal » Sat Sep 10, 2011 10:47 am
Si.
Good to know, as I am doing a COPs conversion this weekend on my track car and WOT is all I really care about, so sounds like it wont need a tune before the coming weekend..
rascal
Postby rascal » Sat Sep 10, 2011 3:47 pm
well, chalk up another successfull COPs conversion.
After giving up trying to find a matching connector, I ended up just cutting off the connectors to the coil pack and wired up a new plug onto the factory harness to plug my COPs harness into. (I can always make a patch harness with the same connector to mate to the coil packs if needed)
Wired it up, turned the key and it fired first time.. phew...
So, just have to mount them properly so they dont fall out (currently just sitting in there) and tidy up the wiring properly and I can kiss those crappy OEM coil packs goodbye....
I'll post some pics when I'm done...
rascal
Postby rascal » Mon Sep 12, 2011 11:33 am
Wiring was dead easy. Took power, ground and 2-3 trigger from one coil pack connector feed, and 1-4 trigger from other to connect to the four wires in COPs harness.
Extra ground wire from COPs onto rocker cover.
Just made up a quick & dirty hold down plate using 25mm aluminium from Bunnings.
Will probably change this to a under-COP mounting so can take out one plug at a time without having to unbolt all of them, or needing to loosen the rocker cover bolts each time..
Pics..
Users browsing this forum: No registered users and 146 guests
