Clutch problem, but what?
gslender
Postby gslender » Sat Sep 03, 2011 8:50 am
Hi,
Been suffering with regular gear crunch for a while, and thought it was a worn 5 spd in my NA6, but now think I've figured out the issue.
It seems the clutch needs to be firmly slammed into the footwell and it will not crunch - so the clutch isn't disengaging correctly/fully ?? Yes??
I've replaced the clutch slave, but no change. I've got a master and noticed a weeping from the cylinder inside the footwell... So am I on the right track?
Any other thoughts?
G
project.r.racing
Re: Clutch problem, but what?
Postby project.r.racing » Sat Sep 03, 2011 9:01 am
If it is leaking, it is a good start. And has to be fixed anyway. Fix it, replace you fluids and then comfirm the issue to not.
gslender
Postby gslender » Sat Sep 03, 2011 9:30 am
Thanks, that makes and is where I was heading....
