will put on a new clutch and flywheel on sat, and decided to have a bit of driving after that( haven't drive for 3 weeks)
i heard that the running in is important for the first 1500km??? is it true?
if so, what should i do to run it in and is there anything i shouldn't do during the period???
cheers
criss
What to do or not do about running in clutch ???
Re: What to do or not do about running in clutch ???
Ive never 'run in' a clutch. Engines of course, brakes every time, clutch... Never heard of it.
dann cus you dun use clutch at all
- Dweezle
When we installed the xtreme HD clutch, Xtreme just told us not to do any hard launches, or ride the clutch for about 1000ks.
No idea what could happen if anything but decided to take there advice and so far no issues.
Sent from my GT-P1000 using Tapatalk
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Jeremy Clarkson
- PaulF
criss wrote:dann cus you dun use clutch at all
Of course he uses it. He kicks it frequently.
PaulF wrote:criss wrote:dann cus you dun use clutch at all
save the clutch on rolling start drag, kick the clutch hard when drift
Dweezle wrote:When we installed the xtreme HD clutch, Xtreme just told us not to do any hard launches, or ride the clutch for about 1000ks.
what you mean by "ride the clutch'??
It means dont slip it excessively.
NitroDann wrote:It means dont slip it excessively.
got it =], thx dann
helpful as always
- Russellb
- RIP Nov 2014
Big thing is to recheck and adjust the free play after about 1000KM of driving.
as the clutch fricton plate wears in it MAY require adjustment.
it is more an ARSE covering thing for mechanics than anything else
My ClubmanRebuild
MX5 SE Rally car is HERE
Running in a clutch is not necessary. Abusing clutches such as riding a clutch - example driving with pressure on the clutch pedal is a good way to shorten its life.
Thanks for advice guys
will put the clutch in tomorrow, will try to be more carful on the pedel fot sure
Users browsing this forum: No registered users and 144 guests
