Custom wheel adaptors
If anyone is interested iv found a company that makes custom wheel adaptors, which allow you to choose size, a new bolt pattern etc
http://www.motorsport-tech.com/wheel_adapters.html
Thought I should share
Cheers eren
Cheers eren
I dont care that my laces aren't fat or that I'm not even close to flush and I certainly don't want to be the illest!
- Steampunk
Re: Custom wheel adaptors
I need to run 17's to fit over my AP 330 mm disks and would like to run 17x9's with 235/40/17 semi slicks and have thought about wheel adapters.. Is the only problem that they act like spacers. I am thinking of running 15x10 on the back with 250/585/15 slicks and using my current 215/45/17 slicks on the front. Seems a bit odd having 2 inch smaller wheels on the back but it gives me 35mm more tyre on the back as wheel spin out of corners is a big issue with 180rwkw and 700 torques. ...
ANY THOUGHTS ?? Patrick
- Vehicle: Non MX-5
plate style spacers and bolt on adaptors are 2 very different things.
- 16bit
just get special order work emotion 11r in your psd. easy as pie.
Some dont want to spend thousads on wheels when 6ULs are just as good and very cheap.
Im sure patrick is included.
HELP PLEASE..Where is the best place to buy the work Emotion 11r. Japan/USA/other .They seem to have 17x9 in +17,+28 and +38 in PCD 4x100 .What offset will go with coilovers and rolled guards..I think the offet on 15x10 6ul's is +25..thanks Patrick
Lol,
Ill shut up now..
Ill shut up now..
I only want 2 for the rear, much better to have 17's with 245/40's..come on Dan wher can I get them from?? Somewhere that doesn't charge $500 for freight..PB
Cant you talk to someone like http://www.metalspinnersaust.com.au/met ... pgodEGtX8Q or maybe see who is doing Simmons wheels these days. For a very specialised application it is worth getting the right thing for the right job and getting a set made to suit...it will be safe and it will be money well spent as it will work!
- Vehicle: Non MX-5
wheel Warehouse in Brisbane brought most of Simmons old manufacturering gear. They still do custom sizing in 15s and 17s only.deviant wrote:Cant you talk to someone like http://www.metalspinnersaust.com.au/met ... pgodEGtX8Q or maybe see who is doing Simmons wheels these days. For a very specialised application it is worth getting the right thing for the right job and getting a set made to suit...it will be safe and it will be money well spent as it will work!
I am going to find out Monday about changing the rear hubs to 5x114.3. Then 17x9's are a time a dozen. Patrick
Nice let me know how Pat!
Im looking to upgrade my hubs as well as i want to run bigger bearings in the hubs so i can get the engineer to sign off on my new wheels
Cheers eren
Cheers eren
