Cost of CAMs
- Dweezle
Re: Cost of CAMs
I rang and spoke to Wendy.
She asked for my email address and that was the reply I got.
I called back and asked because there website said otherwise.
She informed me I was incorrect haha..
Hope you have better luck.
$300 each is not bad.
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Jeremy Clarkson
- Novice1
Re: Cost of CAMs
I have just put a new set of tighe cams in my car, the billeted tighe,s that were in my car had some wear.
On standard cams I am only able to run 8 psi and around 132 kw atw, on the billeted cams I was able to run 12 psi and 168 kw atw. Eventually I will get round to putting up the old cams for sale.
Anyone interested I can email pictures, specs.
Cheers novice 1
Cheers novice 1
Re: Cost of CAMs
Sorry whats stopping you from running 12PSI on stock cams?
- Novice1
Re: Cost of CAMs
Stock cams didn,t have lift, duration to do so. Something about detonation I suspect.
Cheers novice1
Cheers novice1
Re: Cost of CAMs
Somebody isnt being truthful to you.
Bigger cams result in LOWER boost pressure ratios at the same compressor flow levels.
Did the tuner sell you the cams?
- Novice1
Re: Cost of CAMs
No the tuner didn't sell me the cams it may be that the car was running a lower brand octane fuel on the day, which I had forgot about
Cheers ron
Cheers ron
Re: Cost of CAMs
Boost pressure is only a measure of reestriction.
So going to bigger cams allows you to make the same power with less boost. Obviously more power with cams is intuitive, but on a turbo car what you're doing is reducing restriction, which means lower boost pressure at the same flow (remember flow = power) or alternatively, more power (flow) at the same pressure.
Many are running 15-20 psi on a stock engine, bottom end, compression, cams and all. Some are running GT2554s with the wastegate wired CLOSED just to see what can be done on the stock bottom end, one bloke has been running this for like 6 months.
How much boost is he running? All of it!
- Novice1
Re: Cost of CAMs
According to dean tighe and Gary Stewart my new cams will allow me to run more boost.
Previously timing was set up for a n/a car. It has now been set up for turbo. I am told the idle will be better which is readily noticeable already.
Tuning next week.........love your thread nitro on your car.
Cheers novice1
Cheers novice1
Re: Cost of CAMs
Thanks
Your cam timing helping you run more boost refers mostly to overlap. They may be the same total duration, but the cams overlap is likely different (most likely greater, reducing dynamic compression). If you imagine adjustable cam gears, this is like rotating the intake cam anticlockwise, and the exhaust cam clockwise. The cam lobes havent changed, so lift and duration havent changed one bit, but you've moved the cams 'away' from each other, so overlap is reduced.
Re: Cost of CAMs
hmm...even a regrind is appealing to me just for a little bit more grunt - esp for what...420 or whatever?
viewtopic.php?f=73&t=62834
Re: Cost of CAMs
A regrind will get you bigger cams than tomei procams.
Re: Cost of CAMs
that price that was quoted earlier...was that for 1 cam or 2 to be regrinded?
Re: Cost of CAMs
Both.
Re: Cost of CAMs
Both as 1 lot or each?
not clear sorry dann
- Dweezle
Re: Cost of CAMs
The cost is for both cam shafts.
Intake and Exhaust.
Intake and Exhaust.
Jeremy Clarkson
Jeremy Clarkson
