window for hard top -what are the options?
Re: window for hard top -what are the options?
I think you can buy a flat sheet of polycarbonate from Bunnings...~$50? Not quite sure if it will be long enough, but it should be and it will be a couple of mm thick. It the Dural outlet, it was in the roofing area, near the plywood / MDF sheets.
For that kind of weight, don't know why you'd bother unbolting it Dann.
Because every gram counts.
On top of that, theres less drag with it out.
NitroDann wrote:Because race car
Fixed that for you
From a previous thread. The photo is a screenshot I just took from the same thread.
NitroDann wrote:No fan, No heater, No carpet, No trims, No console, No wipers, No cam belt cover, No spare, No tools, No emissions gear.
BECAUSE RACE CAR
No kidding.
Gladwrap and sticky tape will be very removable for street/track and it will be much lighter than 3 mm thick lexan.
every ounce counts
This is now an 'every ounce counts' 'because racecar' thread.
I only wash my car because dust is heavy.
Why? Because racecar!
You'll see the car in spetember if all goes to plan. It weights half a tonne less than an nc
- Guran
- Vehicle: ND - 1.5
Dann, if you've got no glass at all, why fit a hardtop shell?
Aero.
Its well proven by the guys stateside.
Quoting Savington 'Anybody who races an na/nb without a windowless hardtop has no idea'.
But Ill run with and without to prove it to myself.
- Guran
- Vehicle: ND - 1.5
I'd think a hardtop with no windows/windscreen would create lift due to the curvature of the roof???
Honestly I havent done the tests myself, Ill start with the recommendations of Sav and Emellio and go from there. But ill keep you informed
I would have guessed at massive turbulance coming out of the rear windscreen opening but it can't be as bad as running roofless?
The no hardtop glass thing was 'created' to get clean airflow over the wing. It works.
Users browsing this forum: No registered users and 252 guests
