Shift boot replacement
Apu
Postby Apu » Sat Aug 13, 2011 8:13 am
Two questions:
1. The collar that sits at the top of the boot, on the shifter...how do I remove that? Or do I just break it off?
2. I guess I might as well replace the bottom boot since just about everything is out already? Or are they much more durable?
Thanks!
gslender
Postby gslender » Sat Aug 13, 2011 8:21 am
Top collar will probably tear boot when you force it up, so yes, just break it (assuming your replacement boot came with the collar ring on or with the new boot).
My bottom boot was also broken, so I had to replace it, but if the top boot is worn, then the bottom won't be far away.
G
de Bounce
Re: Shift boot replacement
Postby de Bounce » Sat Aug 13, 2011 9:42 am
If you have already pulled it apart to replace either the upper or lower boot, might as well replace the other.
Guarantee that the one you don't replace will tear sooner rather than later and you will need to do the job again.
There is a guide [url_http://www.camsmx5.com/Resources/techshift/techshift.html]HERE[/url]
If you have a 5speed you should change the oil in the turret!
If you have a 6speed this is not required
Motorkhana Video
Postby Lokiel » Sat Aug 13, 2011 9:51 am
When I installed my SSK, I squirted around it with WD40 and it slid off easily.
Apu
Postby Apu » Sat Aug 13, 2011 12:42 pm
Love this forum! Thanks guys!
Apu
Postby Apu » Sat Aug 13, 2011 5:49 pm
Sure enough, the lower boot is shredded!
Question now is...how do I remove the lower boot off the stick?
I really should have taken pics of it for a guide! I'll try and remember to do this in reverse when I get all the bits back in (short story...the driver for this is that my seats and the shifter and brake gaiters are out re-upholstering)
JBT
Postby JBT » Sun Aug 14, 2011 8:18 am
Cut it off. And yes, the new lower boot will slip on over that fat lever without splitting, just use some KY...seriously. :wink:
Apu
Postby Apu » Wed Aug 17, 2011 10:40 pm
Larry, got the boots today and fitted them. And everyone else, all the tips were most helpful...can't believe it was that easy, haha! :beer:
Bizi
Postby Bizi » Thu Aug 18, 2011 6:51 am
I look forward to seeing the pics and eventually to see how Apu has progessed. Are your seats done already?
I was looking at a cheap suede gaiter/handbrake set on ebay here and would be interested in seeing yours, if you've taken pics.
Hope that you are well. Have you been to the HJT self-serve DIY workshop for this and other things? I hope to follow in your footsteps with this shift boot and the gaiter replacements.
Once a theme for the interior is decided!
Here's a nice pic, for future inspiration: http://i84.photobucket.com/albums/k24/b ... CF3762.jpg
Apu
Postby Apu » Thu Aug 18, 2011 10:14 am
Seats are still in progress. I forgot to take pics of the shift boot replacement :oops:
I got home late...they had arrived...I jumped into the car and installed them. It's very easy!
PaulF
Postby PaulF » Thu Aug 18, 2011 1:22 pm
Bizi wrote:Here's a nice pic, for future inspiration: http://i84.photobucket.com/albums/k24/b ... CF3762.jpg
Very multicultural: A "Miata" (LHD) with "Roadster" speaker covers and "MX-5" scuff plates.
