NA6, so hot right now!
specmiata
Postby specmiata » Fri Aug 12, 2011 12:11 pm
Hi all,
Had a crack'in day at the Winton track day last Sunday, drove home to Melb. never missed a beat, i drove the car to work on Thursday, after a 40 min. drive (in some traffic) or the first time ever i noticed my thermo fan come on and stay on after i turned the car off. I came back to it 30mins mins later and the fans were still on...the gauge was still only on half which is what it normally on.
I felt the top hose and it was HOT, top of the radiator was HOT, but the bottom hose was cold.
May be a dumb question but is this a stuck thermostat, or some thing more serious!!
TSM
The older i get...the faster i was!
Re: NA6, so hot right now!
Postby Okibi » Fri Aug 12, 2011 12:34 pm
To me it sounds like a stuck thermostat (that is letting some heat past into the top hose) or a dead water pump.
specmiata
Postby specmiata » Fri Aug 12, 2011 1:14 pm
What's the easiet way to diagnose thermostat versus water pump? I think i will take the opportunity to flush the coolant etc.
TSM
jerrah
Postby jerrah » Fri Aug 12, 2011 1:23 pm
The coolant fan was on even though the ignition was turned off? Sounds like a stuck relay of some sort.
1991 MX5
specmiata
Postby specmiata » Fri Aug 12, 2011 1:31 pm
Yeh, i thought that was also weird....
It stayed on for a good 30-40 minutes after i got home, i eventually un-plugged it to stop the battery going flat.
So diognosis so far, is potential stuck thermostat, or busted water pump (or both) , and dodgey thermo fan relay????
Is the the relay a Mazda spare part?
TSM
bigdog
King of the kennel
Postby bigdog » Fri Aug 12, 2011 1:36 pm
Fan switches off with ignition regardless of temp. Busted relay is my guess. If the engine was hot the gauge would have moved, so no drama there, just the relay.
Postby Jeo » Fri Aug 12, 2011 1:39 pm
You sure about that Bigdog? The fan on my NA6 will occasionally stay on for a minute or so after the ignition has been switched off, after a quick but spirited track session. Most commonly occurs after a single lap event like a hillclimb.
bigdog
King of the kennel
Postby bigdog » Fri Aug 12, 2011 1:55 pm
On my NB it switches off - I was looking at rewiring mine to stay on till the temp drops to save popping the bonnet up after runs. I stand corrected if the NA has more sensible wiring :D Nevertheless I think the OP's relay is toast.
jerrah
Postby jerrah » Fri Aug 12, 2011 2:13 pm
My NA (and other NA's I've used) have never kept the fan on with the ignition off.
1991 MX5
specmiata
Postby specmiata » Fri Aug 12, 2011 2:27 pm
OK, so as a process of elimination, should i remove / replace, thermostat? and replace thermo fan relay, then see if problem solved? if not repalce water pump??
TSM
jerrah
Postby jerrah » Fri Aug 12, 2011 2:40 pm
Well is there any other signs of overheating or is it just that the fans are staying on? Have the fans ever gone off since?
Thermostat is pretty easy to replace in a stock MX5 (mine is now at the back of the head) I find it very unusal that the fans stay on with the ignition off.
http://www.miata.net/garage/CoolingSystemProblems.html
the fan should activate if the ignition switch is on
http://forum.miata.net/vb/archive/index.php/t-249000.html
Should the fan run with the ignition off ?
Nope. If that happens, the fan relay got stuck closed, and it has happened to some owners here.
1991 MX5
specmiata
Postby specmiata » Fri Aug 12, 2011 2:50 pm
Temp gauge was at normal pos., no other signs, i did notice it getting hot through the Gearbox tunnel in the cockpit, my car is a track car so no carpet etc.!
Did start idleing a littler higher than normal...
After i unplugged the fans after they were running for 40mins at home, i have not dríven it again until i sort it out...
TSM
specmiata
Postby specmiata » Fri Aug 12, 2011 4:08 pm
OK, so just priced the Thermo fan relay from Mazda ($50) and to buy the thermostat gaskets require you to buy it with one of the hoses that attached to the thermostat housing ($140 ex-Japan), oh and priced a Water pump just in case ($239).
Hoping for a weekend job, does anyone know if the relay needs to be OEM, Mazda can't get one for 4 days...
TSM
Postby Okibi » Fri Aug 12, 2011 5:05 pm
Sorry if my comment led you astray, I got the impression your car was running hotter than standard just try a relay first.
Postby manga_blue » Fri Aug 12, 2011 5:12 pm
Sounds like nothing's wrong with the thermostat. Hot water exits the head, passes through the thermostat into the top of the radiator. It cools on the way down and emerges just warm at the bottom before going through the pump and engine again. No problems.
The fan relay is probably toast though.
