Painting rocker cover
- Vehicle: ND - 2
Hi guys,
I've just purchased a spare rocker cover, with the intention of paintin it up. Just wondering what methods people have used to paint theres, and if people want to post some pics up? sort of a show off your engine bay/rocker cover thread I guess?
Re: Painting rocker cover
VHT Wrinkle Red or Wrinkle Black would look good.
Wrinkle Red would make it look like an SE's rocker cover.
With the Wrinkle paint, to get the best wrinkle effect you need to bake it in an oven.
- Old Dude
Lokiel wrote:VHT Wrinkle Red or Wrinkle Black would look good.
And hope Mum Doesn't find out
MX 5 2001 Grace Green
NB8B
NB8B
- Vehicle: ND - 2
I was thinking of doing mine in wrinkle black, but i want to do the Mazda and DOHC part in different color, how should I do that, paint them first and then mask over it to do the black?
I've been wanting to do the same and in wrinkle black - apparently no need to bake that?
I will paint the lettering as well but figured it would be easier to do it after. Just let the rocker cover dry, then use a small syringe to dribble paint into the cavities. Will do it in silver to match the car.
Have a look here for some ideas/hints : http://clubroadster.net/vb_forum/showthread.php?t=10066
- gslender
VHT say the engine heat itself will also work... Just needs to be 100 deg for 20 mins.
G
- Matty
Did mine in VHT wrinkle black - no need to oven bake, but you could smell it curing when reinstalled on the car.
Prep was just a good clean with metho, applied then dried in the sun. A little help from a hairdryer I think too.
Matty wrote:Did mine in VHT wrinkle black - no need to oven bake, but you could smell it curing when reinstalled on the car.
I find that baking after each wrinkle coat produces better/more-pronounced wrinkles.
Also, don't call it a "hairdryer", we get enough crap about the MX5 being a hairdresser's car - it's "an entry-level hot air gun"
If you've got too much spare time ..
at the last Kurri Nostalgia festival there was an entire 50's aluminium aero caravan almost that good,dont know how they do it,find the time that is,or the determination not to quit when its only good enough.
Mick
Mick
Okibi wrote:If you've got too much spare time ..
+1 but that one looks not to hard (mostly flat and not many crevice)
You should try the intake plenum and rocker-cover on a mr2...lol
here was mine after painting it with the VHT caliper paint (worked a treat)
At first i just painted it and was happy ... but then
now with a POD and changed all the bolts over for stainless Allen bolts (also needs a clean)
took at least 2 weeks after work with the buffing wheel and sand paper
FYI if you go down this path the buffing is easy part.Sanding and prep is long, boring, and hard
also polished alloy needs re-polished or clear coated to keep looking epic
(haven't found a clear coat that keeps it clear they seem to make it a tad milky)
polished engines do look good, after all my MR2 won ToyoShow 2010 best engine bay
haven't looked at pimping my nc due to all the plastic covers but it will probably happen some time
maybe perspex with neon and chrome mmmmm
Yeah i've got a little crazy with polishing parts in the past
Okibi wrote:Yeah i've got a little crazy with polishing parts in the past
No kidding!
I took it off to paint while doing the timming belt.
I used the dishwasher to clean it with a bit of extra soap so all the oil was removed
Then I sprayed it and cooked it the oven to make it dry and wrickle up.
If I could do it again I would go black once you get a bit of oil on it its kinda hard to clean off.
every ounce counts
Users browsing this forum: No registered users and 143 guests
