NitroDann's Long Awaited Garage Thread
Re: NitroDann's Long Awaited Garage Thread
Postby NitroDann » Mon Aug 01, 2011 9:00 pm
As you know I get so many pms regarding technical things like this. Ive recently recieved a few requests for a writeup on this and the SNC 'issue' so I decided to write it up while I was in there. Take the post and sticky it if you think it will help?
Postby NitroDann » Tue Aug 02, 2011 6:32 pm
I just recieved this text message from 'xatz' on here..
'Seam weld. Thats one modification you havent done yet =]'
God dam, The engines out and the welder is primed.
Who says do it?
deviant
Postby deviant » Tue Aug 02, 2011 6:57 pm
Like this you mean? http://www.flyinmiata.com/tech/seamweld.php
Not that I am trying to put ideas in your head or anything.....
Postby NitroDann » Tue Aug 02, 2011 7:05 pm
Thats the one......
Anyone with experience on an MX?
My ae86 is done, but no experience with my 5.
PaulF
Postby PaulF » Tue Aug 02, 2011 8:27 pm
Do you honestly think anyone is going to say "Nah, that's a terrible idea"? Admit it, you're going to do it. You just want a bit of extra justification, and maybe some people to blame if you somehow screw it up. :P
Postby Okibi » Tue Aug 02, 2011 8:37 pm
One of our club members had his race car seam welded many moons ago, hard to tell what effect it made as it was caged at the same time.
Postby NitroDann » Tue Aug 02, 2011 8:41 pm
Do you know what/where he welded?
What was his weapon of choice? Tig, gas mig? Did he use a spot welder on the door opening seams etc?
rob323
Postby rob323 » Wed Aug 03, 2011 8:53 am
If I seam welded another car, I'd tig weld the door way seams again but I would try to silicone bronze braze the overlapping seams instead of mig'ing them (this would depend if the seam sealant would allow it) as it would save a lot of corrosion issues down the track.
I would not do it to a road car though, pure race car only.
Don't drive it........RALLY it!
Postby NitroDann » Wed Aug 03, 2011 9:17 am
why wouldnt yu do a road car though?
I figured around the shock towers, down the pinch weld with a spot welder and then do the door surrounds with a spot welder and call it a day?
rob323
Postby rob323 » Wed Aug 03, 2011 11:03 am
I wouldn't seam weld a road car cause of the corrosion problems you cause by not being able to get to the back of some places to treat the metal. Oh, that and you make it illegal cause in theory you have changed the way the car crumples in an accident :roll: .
If a particular area "needs" to be reinforced (suspension mounting points etc), then by all means, go for it.
Postby NitroDann » Wed Aug 03, 2011 11:42 am
Ill at least spot weld the door seams and the pinch welds because its very easy and normal practice when doing panel work.
Any issues you can see doing that?
rob323
Postby rob323 » Wed Aug 03, 2011 12:11 pm
Nope, a 20mm long tig weld would be stronger though, but in reality, we're probably splitting hairs.
Postby NitroDann » Wed Aug 03, 2011 12:21 pm
Sweet thanks mate. Im thinking one every 2 cm.
Postby NitroDann » Wed Aug 03, 2011 7:23 pm
Quick update. Engine and box back in the car. Diff out tomorrow and Ill start on the suspension arms for the bushes.
TOYOTA COPS UPDATE:
Im waiting on pricing for the actual coil packs because im going to buy 30 odd at a time.
Im also waiting on finalisation on the carbon fibre hardware for fitting them.
Im waiting on confirmation for one last test set, as I have 2 cars testing them at the moment but one has a non cops related issue at the moment, so im looking at another tester.
The ignitors WILL be exchange, as I cannot get well priced ones and you wont need it once youve gone cops.
PaulF
Postby PaulF » Wed Aug 03, 2011 8:51 pm
PM me if you're in want or need of a tool bitch in the next couple of days. :P Pretty sure I'll be free, as usual... :roll:
Users browsing this forum: No registered users and 104 guests
