Yellow Speed Racing coilovers - DD?
ll_spud
Postby ll_spud » Sat Jul 30, 2011 10:33 pm
Hi,
I'm looking at upgrading my stock suspension for a daily drive 1995 NA8. And at the same time lowering it slightly.
There's currently a GB on the sponsors section for the Yellow Speed Racing coilovers being a bit over $800 a set. Price is very reasonable.
http://www.mx5mania.com.au/product1810.htm
Would you recommend this for an upgrade to daily drive? I'm also considering a set of Tokico Illumina. Or am I wasting my money. The car will not see the track.
I want to retain a nice comfort ride for DD. Any suggestions would be appreciated.
THanks.
Re: Yellow Speed Racing coilovers - DD?
Postby NitroDann » Sat Jul 30, 2011 10:44 pm
My car has a fixed sparco bolted to the floor. No carpet. No windows. No soft top. No rear hardtop window. No heater. No fan. No console. Button clutch. Running on alcohol every day, with super hard HKS coilovers and plenty more.
I consider it a perfectly daily-able car. I doubt you would. I do daily it. Cops ask me if its even registered.
The question is what do you consider to be dailyable?
But if what your asking is, 'are these yellowspeeds stiff?'. The answer is god yes.
Postby NitroDann » Sat Jul 30, 2011 11:21 pm
Patrick who owns casper, the mx5 club outright all time wakefield park lap record holder, had me rremove his yellowspeeds from his na8(blown serious daily/track car) because they were just stupid uncomfy.
Also, super soft damping with stiff springs feels comfy for half an hour, then its bouncing up and down so quick you need to stop and pee. Half an hour later guess what. Pee break again.
You wont believe what happens half an hour later again... Yep you guessed it, pee break.
So dont just think youll set the, to full soft and it will be comfy, because the dampers can no longer control the oscillation.
Hjt
Postby Hjt » Sat Jul 30, 2011 11:23 pm
As PM states, get Koni Shocks and some King Springs.
This combination will give you the desired results cheaper and with no real losses in drivability.
ll_spud
Postby ll_spud » Sat Jul 30, 2011 11:35 pm
Where abouts can I get these Konis? Mx5mania are selling them for a bit over $1000 for the set. No springs. Not that cheap.
Postby NitroDann » Sat Jul 30, 2011 11:37 pm
:NETPOINTZ:
What hayden said.
Hjt
Postby Hjt » Sat Jul 30, 2011 11:39 pm
http://www.shox.com
I haven't bought from here, but everyone else seems to at some point and there time to deliver etc has always been very responsive.
Hjt
Postby Hjt » Sat Jul 30, 2011 11:45 pm
More specifically the prices are all in US$, so after conversion the prices are reduced even further.
010. Koni sport suspension 1989 - 1997 Set of four springs and sport shocks, lowers 35mm 749.00
012. Koni sport shocks 1989 - 1997 Externally adjustable shocks, price is for a set of 4. Shipping is free. 630.00
013. Koni Street Shocks 1989 - 1997 Set of 4 F&R #8050-1041 fr 8050-1042 rear Free shipping 296.80
018. Bilstein HD Shocks 1989 - 1997 Gas pressure shocks, price is for a set of 4 F&R. 389.00
026. Tokico Illumina Shocks Y 1989 - 1997 Externally adjustable shocks, price is for a set of 4 F&R 459.00
040. Eibach Pro-Kit Springs FREE SHIPPING 1990 - 1998 Free shipping U.S. 48 states. (Canada, PR, HI , AK please call for reduced rates).Lowers car 1.0 inches (5515.140) 210.56
055. Eibach Sway Bar Kit 1990 - 1998 Kit contains front 24mm & rear 15mm bars (5515.320, 5517.320)(aa)(ab) 236.16
065 Tokico Advanced Handling Kit 1989 - 1997 Kit contains springs and non-adjustable gas shocks. LOWERS 1 INCH FRONT AND REAR 449.00
070. Tokico Ilumina Adv Handling Kit 1989 - 1997 Kit contains springs and Externally adjustable gas shocks. Y07 599.00
078. Eibach Coil Over kit 1990 - 1998 Stainless steel coil over kit (5515.711) 1196.00
080. Koni Coil-Over Kit 1989 - 1997 Kit contains springs and externally adjustable shocks. 1344.00
101. Eibach Pro plus kit Pro kit springs and sway bar kit 1989 - 1998 5515.880 Package with both springs and sway bars 402.04
ll_spud
Postby ll_spud » Sat Jul 30, 2011 11:50 pm
In that respect, should I consider the Koni sport or street? I'm doing some research now however, don't know if I should spend the extra for sports if i'm not going to track it.
Postby NitroDann » Sat Jul 30, 2011 11:55 pm
You sound like you just want to replace flogged stuff, and a bit of an upgrade for the sake of it would you agree?
Do you do mountain runs (ie take it to twisty roads with no other intention except to flog the piss out of it)? Or just go to the shops/work?
Hjt
Postby Hjt » Sat Jul 30, 2011 11:56 pm
From what I can see, your best selection from the above mentioned is...
and
Total of 507.36 US $ at current conversion rate that would be 463.15 Aus dollars
This would give you good quality shocks, that aren't adjustable combined with Eibach springs that are reliable and 1 Inch lower than current ride height.
Eibach are just as good quality as Kings in my personal opinion.
ll_spud
Postby ll_spud » Sun Jul 31, 2011 12:13 am
Daily drive and a bit of mountain fun on weekends. Nothing serious.
I'm currently running on stock shocks, with lowered springs. It drives fine, however, starting to annoy me when it bottoms out over shopping centre speed bumps and its a bit bouncy.
I'm wanting to make the car more comfortable to drive. I've been in my mates NC and was quite happy with the ride. I believe they come in Tokicos. Hence wanting to upgrade to the illuminas. But don't know if it's worth it for an DD.
I've never thought/ or considered the Konis' before. But am looking into it now.
ll_spud
Postby ll_spud » Sun Jul 31, 2011 12:18 am
Oh, and would the KYB GR2 be a similar product to this? A local seller has offered them to me. Might be cheaper for postage. thanks
ll_spud
Postby ll_spud » Sun Jul 31, 2011 12:19 am
GB is here for those who are interested:
viewtopic.php?f=82&t=48119
Dweezle
Postby Dweezle » Sun Jul 31, 2011 12:26 am
Biggest problem with NA suspension is lack of travel in the rear.
Always amplified with lowered springs. (the Bottoming out and Bouncyness you are getting).
Koni with Kings is a great road/track setup but to gain the most from any lowered setup you really need different Top Hats for the rear.
Google search TOP MOUNTS NA MIATA and you will find a huge amount of info on them.
You can buy new top mounts from FAT CAT MOTORSPORT and Flyin Miata.
FCM (FAT CAT) are great as you can order there redesigned Bump Stops which are a huge improvement over OEM.
Have a bit of a read on the matter and you should have a better understanding of what you need.
The FCM site has some great easy to understand info.
http://www.fatcatmotorsports.com/
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Users browsing this forum: No registered users and 350 guests
