Odometer not visible
Divo
Vehicle: ND - 1.5 GT
Postby Divo » Sat Jul 30, 2011 6:27 pm
Hi all,
Any ideas as to why the odometer/tripmeter is not working ? It's a 2002 NB. I'm building a Clubman and using the factory loom and ECU. All the warning lights light up when powered up in the cluster, but not the odometer or the night lighting. Is there a separate fuse or earth for it? I haven't got the rear loom but the front lights connectors are all still in the front loom. Headlights, indicators and park lights all operate.
I'm stumped ?
Mark
Re: Odometer not visible
Postby 93_Clubman » Sat Jul 30, 2011 6:58 pm
Divo wrote:Any ideas as to why the odometer/tripmeter is not working ? It's a 2002 NB. I'm building a Clubman and using the factory loom and ECU. All the warning lights light up when powered up in the cluster, but not the odometer or the night lighting. Is there a separate fuse or earth for it? I haven't got the rear loom but the front lights connectors are all still in the front loom. Headlights, indicators and park lights all operate.
NA6 & NA8 at least has two fuse boxes - large one in engine bay on drivers side & small one under dash on drivers side. From memory under dash one contains fuse for instrument lights. Think this carried over to NB8.
Divo
Postby Divo » Sun Jul 31, 2011 7:59 pm
Checked the fuses - not the problem. Bugger!!
Mark
Divo
Postby Divo » Wed Aug 17, 2011 9:01 pm
Light problem solved - bridged the dimmer switch connector and now have instrument lights.
Still can't get the odometer to read though.
mark
Divo
Postby Divo » Sat Aug 20, 2011 7:54 pm
Had the cluster bench tested and everything works out of the car including the odometer. I guess that means a wiring issue - bad earth / or no power to the odometer ? Am I correct in this assumption?
cheers
Mark
