Are All NB Diff carriers/housings the same ?
selaga
Vehicle: NB8A - Turbo
Re: Are All NB Diff carriers/housings the same ?
Postby selaga » Thu Jul 28, 2011 7:58 am
I meant to say Inner CV's not Outer.............
Spline count (Inner) = 28 male
Halfshaft = d24mm
Inner CV joint hashed area (in between the splines and the seal flange) = d30mm
Inner CV joint spline area = d30mm
Standard 1.8 carrier/housing = SE carrier/housing.
Standard 1.8 axle seals = SE axle seals.
Hope that help you guys out.
Sel
If it's free...take two...
NB8A Turbo
Caldina GT-FOUR
ELFIN MS8C #15 Gen III
flycasta
Postby flycasta » Thu Jul 28, 2011 8:09 pm
I have been searching for the elusive 28 spline in Mazdas, apart from the early RX4 13B and RX5, and it appears we have out first candidate.
Does anyone know of any aftermarket LSD's for them?
The NA8 and NB8 are the same as the NC and have 26 spline.
selaga
Postby selaga » Thu Jul 28, 2011 8:34 pm
flycasta wrote:I have been searching for the elusive 28 spline in Mazdas, apart from the early RX4 13B and RX5, and it appears we have out first candidate.
Mentions 28 spline.... http://www.mx5mania.com.au/product651.htm
NB8A Turbo
Caldina GT-FOUR
geofiz
Postby geofiz » Thu Jul 28, 2011 9:42 pm
selaga wrote:I meant to say Inner CV's not Outer.............
Halfshaft = d24mm
Sel
Just measured the standard NB8B axles
Spline count (Inner) = 26 male
Inner CV joint hashed area (in between the splines and the seal flange) = d28mm
Inner CV joint spline area = d27mm
Seal surface = d35mm
Russell
NB8A - mostly stock for now
flycasta
Postby flycasta » Thu Jul 28, 2011 10:06 pm
Yeah I think what they are saying there is that they suit everything and also the 28 spline but they are referring to the RX4 13B and RX5 diff's. It doesn't mention that they are suitable for the SE which will need circlips grooves inside the side gears to accept the circlips on the CV joints whereas the RX4 13B and RX5 dont need the circlip grooves.
They may well make them to suit the SE as well, dont get me wrong I am not saying they wont, just never checked one to say they will. If the SE has a Type 2 torsen already you wouldn't need one anyway, I was more thinking Cusco or Kaaz.
Duane
selaga
Postby selaga » Fri Jul 29, 2011 8:05 am
Russell,
Well done, could you also measure the diameter of the halfshaft, then we can make this a sticky ?
Sel
NB8A Turbo
Caldina GT-FOUR
geofiz
Postby geofiz » Fri Jul 29, 2011 11:00 pm
Halfshaft = d24mm
Sel
Halfshaft = d24.4mm
Russell
bootz
Postby bootz » Sun Jul 31, 2011 10:15 pm
flycasta wrote:Yeah I think what they are saying there is that they suit everything and also the 28 spline but they are referring to the RX4 13B and RX5 diff's. It doesn't mention that they are suitable for the SE which will need circlips grooves inside the side gears to accept the circlips on the CV joints whereas the RX4 13B and RX5 dont need the circlip grooves.
Duane
Great to hear from you Duane, always interested in your comments. BTW my diff is superb! 8)
flycasta
Postby flycasta » Mon Aug 01, 2011 12:09 am
Good to hear Ian although I couldn't imagine anything would go wrong with.
Have you had any wet weather to notice the Torsen yet?
Do you still think it was the right choice of ratio?
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Mon Aug 01, 2011 8:57 am
The outer Cv on the SE. Half shaft is bigger than the stock NB8B... The rear uprights are the same but with the SE they remove the seal that sits in the upright.
Users browsing this forum: No registered users and 139 guests
