Few questions
slimx
Few questions
Postby slimx » Thu Jul 28, 2011 7:06 am
Ok i got a Series II NB
Question 1. COWL INTAKE how the F*** to do it with ABS (and the stupid washer bottle)
I want to make my own "cowl-style" intake.. How do i do it??
Whats the best way.
I will be using, stock intake piping to start off, heat shielded pod filter, and then a flexible hose. and .well.. whatever else i need after that.
atm my setup is just stock pipe, air filter, flexible hose that goes below the PASSENGER headlight into that hole where the wheel is.
Question 2. Increasing throttle reponse time
Ive owned this mx5 for a while now, after putting an exhaust on and changing the air intake, i realised i did increase the response time a little and it did help me enjoy the car as much as i enjoyed my old HONDA :)
How ELSE would i go about (light mods only) increasing the response time, i did some research before posting and it seems to me that shorter your intake is .. FASTER your throttle response is?
How would i shorten the intake and still get cold air though?
Would it be a good idea to .. put the pod filter AND then run the intake tubing? i dont think it'll fit but im sure you can buy smaller pod filters...?
Question 3. Wheel spin (whilst shifting)
I like it.. so i dont care about opinions my only question is .. what can i do to get BETTER Wheel spin atm i can JUST barely get it 1st - 2nd. Double Clutch can get it.. again.
Other cars, if you accelerate WHILST you depress the clutch shift and let go .. YOUR garunteed wheel spin it seems the mx5 is not.
Most cars that get good wheel spin seem to have a HD clutch, does this help? Or .. am i chasing ..rainbows
magenb
Re: Few questions
Postby magenb » Thu Jul 28, 2011 9:40 am
slimx wrote:Question 3. Wheel spin (whilst shifting)
smaller/bad tires or more torque, but both of these will put you into a tree.
slimx
Re: Few questions
Postby slimx » Thu Jul 28, 2011 9:43 am
So u reckon just bald tyres help??
jerrah
Re: Few questions
Postby jerrah » Thu Jul 28, 2011 9:52 am
I have no trouble spinning my tyres launching in 2nd. :P
More power, higher revs, crappier tyres, more/less tyre pressure, less grippy surface. Decrease friction or increase torque.
1991 MX5
Re: Few questions
Postby NitroDann » Thu Jul 28, 2011 10:04 am
No for throttle response you want maximum volume between the filter and throttle body. Not the other way around. Buy an arc inlet chamber.
Wheelspin, get a drift clutch. And a blower and use plastic tyres.
Re: Few questions
Postby Jeo » Thu Jul 28, 2011 10:08 am
I normally have a pretty hard time launching at my local hillclimb without spinning the wheels.
jerrah
Re: Few questions
Postby jerrah » Thu Jul 28, 2011 10:10 am
Jeo wrote:I normally have a pretty hard time launching at my local hillclimb without spinning the wheels.
Hence trying the 2nd gear launch. Got me going with a minimal fuss. But lit the tyres up easily in 2nd on the burnout pad.
1991 MX5
Re: Few questions
Postby NitroDann » Thu Jul 28, 2011 10:12 am
Not burnouts, he wants to drop it into second and chirp so everyone thinks hes hard.
jerrah
Re: Few questions
Postby jerrah » Thu Jul 28, 2011 10:20 am
Fit a 4.3 or 4.8 open diff?
1991 MX5
Re: Few questions
Postby NitroDann » Thu Jul 28, 2011 10:35 am
Davex3 wrote: HEY MAN I THINK YOU SHOULD REPLACE THE WHEELS WITH CARBON FIBRE LOLLIES AND THEN HERP DERP THE TURBO HERP.
Re: Few questions
Postby Mr Morlock » Thu Jul 28, 2011 2:18 pm
what are we supposed to do - encourage bad behaviour- hooning is hardly something to aspire to.
CheyneX5
Few questions
Postby CheyneX5 » Thu Jul 28, 2011 2:59 pm
Mr Morlock wrote:what are we supposed to do - encourage bad behaviour- hooning is hardly something to aspire to.
Nor is trolling.
90' NA6 - Classic Red
Benny
Re: Few questions
Postby Benny » Thu Jul 28, 2011 4:00 pm
My car will break into wheelspin at 4,000 RPM when accelerating hard.
Even if I take off easily in first then floor it, when it gets to 4K, the wheels start to spin.
I've had some very surprised and frighteneing looks from passengers when I do this to them for the first time too. :D
Mind you, my car is turboed.
adrianciaff
Re: Few questions
Postby adrianciaff » Wed Aug 03, 2011 1:27 pm
If your looking for better throttle response/ acceleration and would like to be able to produce more wheelspin with the limited power that the mx5 holds naturally... Then I would reccomend a lightwight flywheel + HD clutch upgrade. This is not the cheapest nor the easiest option but from personal experience it will deliver pretty much exactly what you have explained - whether you have bald tires or not wheelspin is easily achieved and the car will accelerate moderately harder up the rev range in the first 3 gears.
On a more simplified note: have you checked the tention on your throttle cable? Lol.
Adrian
Benny
Re: Few questions
Postby Benny » Fri Aug 05, 2011 4:59 pm
Flat changing might also help your problem.
The rev limiter will stop the engine from overrevving.
