Clicking brakes
red devil
Clicking brakes
Postby red devil » Mon Jul 11, 2011 12:37 am
I seem to have a clicking noise from my front right calliper
My car is a NA 1.6 and they are off an NB8A
I have greased the sliding pins and it has lessened the noise slightly, any ideas?
Cheers Eren
I dont care that my laces aren't fat or that I'm not even close to flush and I certainly don't want to be the illest!
Charlie Brown
Re: Clicking brakes
Postby Charlie Brown » Mon Jul 11, 2011 2:47 pm
red devil wrote:I seem to have a clicking noise from my front right calliper
Cheers Eren
Missing the spring steel location clips so the pad's just floating around in the caliper slot?
See here: http://www.mx5parts.co.uk/product_info. ... cts_id/954
Re: Clicking brakes
Postby NitroDann » Mon Jul 11, 2011 2:56 pm
Sounds right. Many lose the locating clips, not to be confused for the backing plates.
Without them, the friction is higher between the disk and the pad, than between the caliper and pad, and so the disk drags the pad around a couple mm until it whacks the caliper.
Its NOT a safety issue i might add, hopefully give you some relief.
red devil
Re: Clicking brakes
Postby red devil » Mon Jul 11, 2011 3:22 pm
thats sounds like the problem!
Like Dann said it hasnt affected the braking performance any, but its just so farking annoying :x
I might be getting some new parts ie pad separating springs and clips! i dont have the pad backing plates though, might look into finding some today
Cheers eren
Re: Clicking brakes
Postby NitroDann » Mon Jul 11, 2011 3:45 pm
ont buy the backing pads, they are a major cause of rattling and squeeling due to them vibrating.
Buy a tube of antisqueel. Its a rubbery glue that glues the pads to the caliper, stopping them from making any noise at all. Keep the locating clips but use this instead of backing plates.
RawSouth
Re: Clicking brakes
Postby RawSouth » Mon Jul 11, 2011 3:45 pm
Email Mazdatenfive and see if he has some clips, or if you buy the OEM pads from MX5parts.co.uk, they come with the clips included.
Josh
ロードスター
red devil
Re: Clicking brakes
Postby red devil » Mon Jul 11, 2011 4:56 pm
Nice!
Dann is the blue or orange stuff? or will either do? Locutus has a new set of springs and clips for me, i'll try and grab them off him ASAP
eren
red devil
Re: Clicking brakes
Postby red devil » Sat Jul 23, 2011 7:51 pm
replaced all the clips, separating clips and geased the pins and its all good now :lol: cheers for all the imput!
