Does anyone know where i can get one of these? intake
randymx5
Postby randymx5 » Wed Jul 13, 2011 10:55 am
R&ALL
RED 1990 MX5, AVO stage II, 148.5rwKw
Re: Does anyone know where i can get one of these? intake
Postby NitroDann » Wed Jul 13, 2011 11:24 am
Nope. Looks damned fancy though. Ive seen them before, ive always wondered if anyone had done any pressure testing with them at speed.
mazdatenfive
Postby mazdatenfive » Wed Jul 13, 2011 12:55 pm
Does it stop the need to hack the fire wall?
randymx5
Postby randymx5 » Wed Jul 13, 2011 1:04 pm
mazdatenfive wrote:Does it stop the need to hack the fire wall?
i think it might because the wash bottle still seems to be there
R&ALL
jerrah
Postby jerrah » Wed Jul 13, 2011 1:09 pm
How wide is the inlet across the lip of the bonnet seal?
1991 MX5
BadBong
Postby BadBong » Wed Jul 13, 2011 1:13 pm
If this really works then I'm sure there'll be a line since everyone loves the Mania intake if only it doesn't require drilling into the firewall :shock:
Hjt
Postby Hjt » Wed Jul 13, 2011 1:17 pm
If it isn't the Autoexe one, it seems ti be a similar replica. I know there one is carbon fibre and as I'm on my phone I'm unable to view it clearly. Hope it helps
Postby manga_blue » Wed Jul 13, 2011 1:48 pm
NitroDann wrote:Nope. Looks damned fancy though. Ive seen them before, ive always wondered if anyone had done any pressure testing with them at speed.
Dann's right, you really need to do some pressure testing on one of those. Unlike the Mania style intakes, it looks like it's not picking up air from inside the airbox where there's a known high pressure area. Instead it's getting it from a small scoop at the back edge of the bonnet, which may or may not be a good place.
It also seems to require lifting of the rear of the bonnet off the engine bay sealing strip. This is not a good idea because it allows hot air to flow out of the engine bay into your ventilation supply area, so you could draw hot air into the intake, as well as into the cabin.
Postby 93_Clubman » Wed Jul 13, 2011 3:37 pm
Some big forum discussion ref pressure:
http://forum.miata.net/vb/archive/index ... 19529.html
http://forum.miata.net/vb/showthread.php?t=202643
egads
Postby egads » Wed Jul 13, 2011 4:46 pm
Looks like a gruppe-m intake, not too sure if they are still in production though
'90 red eunos na6
"the saddle club" - rider and horse are one
Postby 93_Clubman » Wed Jul 13, 2011 5:04 pm
Postby NitroDann » Wed Jul 13, 2011 5:48 pm
What manga blue said, i also wonder where you get a filter for it and how much for.
Hjt
Postby Hjt » Wed Jul 13, 2011 7:34 pm
I like the fact the washer bottle appears behind the intake area
Postby manga_blue » Wed Jul 13, 2011 11:26 pm
It seems to be actually inside the intake, which I thought was pretty bizarre, or very lateral, or maybe both. :frown:
plohl
Postby plohl » Thu Jul 14, 2011 9:01 am
I have seen some pictures of a K&N system and iirc they look very similar. maybe i'm on the piss though.
plohl
