PLEASE HELP!! NB speedometer stopped!!!
lonelybutterfly
Postby lonelybutterfly » Tue Jul 12, 2011 11:23 pm
Hi all,
Can anyone help me or give me advice??
My speedo was jumping up and down while i was driving and suddenly stopped working. (2001 model NB)
I am so scared, has anyone experienced this before?
Is it a cheap fix?
Any advice would be appreciated.
Thanks in Advance!!!
Re: PLEASE HELP!! NB speedometer stopped!!!
Postby NitroDann » Tue Jul 12, 2011 11:34 pm
Could only really be 3 things. Speedo cluster, speedo cable or speedo drive.
Did it jump up and down, or down and then back?
lonelybutterfly
Postby lonelybutterfly » Wed Jul 13, 2011 12:57 am
NitroDann wrote:Could only really be 3 things. Speedo cluster, speedo cable or speedo drive.
Yea, for example if the reading is 60km it will suddenly drop to 0km for few seconds then jump back to 60km.
But 70% of the time it sits itself at 0km now while driving.
Any clue?
how much is repair?
I'm so scared!!! :(
Postby NitroDann » Wed Jul 13, 2011 1:53 am
either a stripped speedo drive or your speedo cable isnt secured in the guage properly... Im going 95% its the sppeedo drive gear. I couldnt imagine it should cost more than 150 at worst
Postby Okibi » Wed Jul 13, 2011 2:33 am
If everything else on the dash is working then it's probably not a loose plug on the back of the dash cluster (but is pretty easy to check)
Dann's probably right about the speedo gear, which could be broken, coming loose from the gear box or a dodgy cable connection.
The speedo drive gear is connected to the gearbox and looks like this:
I'm sure forum sponsor MX5 Mania would be able to suss it out for you.
lonelybutterfly
Postby lonelybutterfly » Wed Jul 13, 2011 4:29 am
wow... Thanks so much for the info, I will book in a check up at Mx5 mania, as i assume they would have that part.
I noticed that the gearbox (gear stick) is constantly vibrating when driving, so maybe this caused it?
Is this normal?
Postby Okibi » Wed Jul 13, 2011 9:51 am
MX5s tend to wear out the boot(s) around the gear stick every 60,000kms or so, that could also amplify any vibration from the box. If the speedo gear was seizing and grinding away perhaps that could also cause a vibration. Make sure you mention the vibration to Mania so they know it's something else to look at.
Tony
Postby Tony » Wed Jul 13, 2011 10:02 am
My NB speedo is electronic.
You could check the plug that connects the loom to the sender unit on the gearbox, but I doubt it would have come apart as it locks together.
If you're getting an unusual amount of vibration in / through the gearbox, perhaps the pulse generator in the sender unit has shat itself. The drive gear on the sender unit could be stripped, or the gear could also be spinning on the shaft. Best to get someone to pull it out and check.
'09 NC2
Postby NitroDann » Wed Jul 13, 2011 10:11 am
That really surprises me, the electronic speedo that is..
I have both a 90 model 5 speed and a 2000+ se 6 speed, and both just bolt up and everything is the same, cable speedo included, and I was under the impression that every na/nb box was a straight swap into any na/nb.
maybe they all bolt up and run but the speedo wont?
jerrah
Postby jerrah » Wed Jul 13, 2011 11:09 am
The box is a straight swap, but you reuse the NA speedo drive. AFAIK NB is electronic yes.
eg: http://www.miataturbo.net/showthread.php?t=34919
1991 MX5
Postby 93_Clubman » Wed Jul 13, 2011 11:36 am
Similar problem on another NB: viewtopic.php?f=29&t=42521
NitroDann wrote:That really surprises me, the electronic speedo that is..
viewtopic.php?f=29&t=46608
lonelybutterfly
Postby lonelybutterfly » Wed Jul 13, 2011 1:57 pm
booked in for a service and check up at mania tomorrow, will get it all checked up.
Will update you guys when i find out.
-alex
Postby -alex » Wed Jul 13, 2011 2:52 pm
Best of luck!
Let me know how it goes, I know someone with a surprisingly similar problem :lol:
Sasso - 06/05/10 ♥
JT
Postby JT » Wed Jul 13, 2011 4:44 pm
^ That would be me unfortunately :(
01 NB8B same as yours.
At first it was dropping out for a few seconds when accelerating then it would come back, but it's now progressed to the point where it can be gone for hours.
Had it up on the hoist last week and gearbox fluid is leaking from the sender itself so I'm fairly certain that's the problem.
Just need to find the time to swap it out.
Postby NitroDann » Wed Jul 13, 2011 6:01 pm
So whats in the place of the sender on an nb? Block off plate?
Users browsing this forum: No registered users and 97 guests
