Postby kris » Tue Jul 12, 2011 1:24 pm
Hi Okibi,
Well, I did as you suggested, in my not so smart way, I turned off the car, disconnected the battery from the negative terminal and all hell let loose. The alarm went ballistic. I exaggerate, it was just the normal alarm sound. I couldn't get it to stop, so i ended up disconnecting its plug, unscrewing it and then hiding it under all the blankets and linen i could find until it finally shut up about 20 minutes later. Anyhow, problem partly solved because now my bose and bluetooth work again like best mates.
However, now i don't have my alarm sounder connected, i'm thinking of reconnecting it now, but is there anything i should do or know before i do so? I don't want it to start going crazy again. Now thats its stopped alarming i can look at it closer to see there is only a dial i can access with a screwdriver on the back of it, everything else is sealed shut.
When i change out this battery in the future for a lighter battery how should i replace it with out setting the alarm off? I don't seem to have any instructions with how to deal with my "OEM mazda high spec alarm" option. I'm going to consult my car manual now for any possible guidance.
kris
