NB8 91 or 95 ron fuel?
Was the Aus spec 99 model tuned from factory on 91 or 95 ron fuel?
Re: NB8 question
NB8As can run on 91.
Hamx5ter has been doing it for years and it hasn't affected his driving habits one bit...
- Old Dude
Re: NB8 question
Not sure about the 99 model but the NB8B 2000/2001 was 95 or above, I run mine on 95 with no prolem
Dale
Dale
MX 5 2001 Grace Green
NB8B
NB8B
Re: NB8 question
According to Redbook 91 RON:
http://www.redbook.com.au/used-cars/det ... 1040CF8DDF
Re: NB8 question
Why dont you be nice to your engine and long term bank account balance and run it on good fuel no matter whats the minimum is?
Re: NB8 question
93_Clubman wrote:According to Redbook 91 RON:
Redbook is a good guide. If you lookup 200 and 2001 models, it says 91 ron, which Dale says is wrong
BadBong wrote:NB8As can run on 91.
Yep it seems to run fine, but it will use more fuel if it has been tuned for 95.
Re: NB8 question
magenb wrote:93_Clubman wrote:According to Redbook 91 RON:
Redbook is a good guide. If you lookup 200 and 2001 models, it says 91 ron, which Dale says is wrongBadBong wrote:NB8As can run on 91.
Youve never tuned a car for yourself ever have you.
Re: NB8 question
May I suggest that we focus on the initial question....
*peace keeper - out.
Re: NB8 question
To answer that then, the only relevant difference is knock resistance, and although moving the CAS to change timing is an entire map change that wont affect the timing curve, this will 'fix' the issue with running fuel 4 octane points out.
Please dont give engine tune related advice just because it sounds right and your mates mate once read it on the internet and told you.
- Old Dude
Re: NB8 question
I can't speak for RED book,.... but my information came straight out of my manufacturers hand book that came with the car new and if Mazda recommend to use 95 or better then thats what I will be using
Dale
NB8B
NB8B
Re: NB8 question
Don't know about anyone else but I'm getting sick of this troll trying to insult every member one at a time.
Graham
Re: NB8 question
Redbook is a good guide. If you lookup 2000 and 2001 models, it says 91 ron, which Dale says is wrong
Indeed, RB is only a guide, & it's wrong for the NB8B, but it's not wrong for the NB8A.
viewtopic.php?f=18&t=36865&p=478938#p478938
viewtopic.php?f=29&t=35915&p=466405
The NB8A spanned 1998-2000 & the NB8B spanned 2000-2002.
Re: NB8 question
GP maybe some people think that the forum is a place for giving good correct information when you have it and reading good correct information when you dont. And telling people info you just pulled out of your ass because it sounds about right down at the pub is NOT what the forum is for.
If the info was regarding door trims who cares but not steering brakes or engines please, because thats just negligent.
Re: NB8 question
Again... can we take this offline / into a PM?
Dann - you have PM.
Dann - you have PM.
Re: NB8 question
Back to a more technical question - why does NB8B require better fuel?
Does it have anything to do with VVT?
Users browsing this forum: No registered users and 25 guests
