Attn those of you who have rebuilt rear calipers
mitch_f1
Postby mitch_f1 » Fri Jul 01, 2011 5:29 pm
I am rebuilding my spare set of rear calipers, and I have just found a set of c-pliers that are able to remove the circlip from the depths of the caliper, but i have found that the hotdog pin is covered in a grey grease (not suprising really). What kind of grease is this? I want to replace it, as it is looking a bit gunky (dud handbrake seal). I have some PBR rubber grease, or some permatex slider pin grease, which would be best, or neither?
Thanks
Re: Attn those of you who have rebuilt rear calipers
Postby NitroDann » Fri Jul 01, 2011 5:49 pm
Its probably a super high temp rubber grease.
Im not sure whats on yours, but a regular grease will melt off quick smart.
mitch_f1
Postby mitch_f1 » Fri Jul 01, 2011 5:52 pm
Okay, so the PBR rubber grease is made specifically for brake applications, so it would be super high temp (http://www.pbr.com.au/products/replacem ... lary.shtml). So that is what I am putting in there?
Postby NitroDann » Fri Jul 01, 2011 5:58 pm
Yep, thats the one. A regular moly would just melt of in a second.
mitch_f1
Postby mitch_f1 » Fri Jul 01, 2011 6:01 pm
Yeh. Cheers Dann :)
Users browsing this forum: Google [Bot] and 321 guests
