Do these fit under a nc mx5?
17 x 8 +51 fronts with Advan AD08 225/40
17 x 9 +63 rears with Advan AD08 255/40
Cheers guys.
Mx5 nc rims question
- Vehicle: ND - 2
Re: Mx5 nc rims question
Gmi wrote:Do these fit under a nc mx5?
Cheers guys.
Fronts no problem.
Rear , you going to be going out by 33mm (compared to standard 205's on 7"). Thats 8mm on the offset and 25mm each way on the tyres.
Fronts will be OK, rears will almost certainly foul on the inside.
Rob
So the rear will scrape the inside!! Ok.. 20mm spacers atvthe rear and I'll be running go kart wheels ( tyres sticking out of the guard ) ???
Nope, +63 means that the mounting flange on the wheel is 63 mm toward the outside from the centre of the wheel.
Bigger the number, further IN the wheel sits.
Rob
- Vehicle: ND - 2
Gmi wrote:So the rear will scrape the inside!! Ok.. 20mm spacers atvthe rear and I'll be running go kart wheels ( tyres sticking out of the guard ) ???
Go with 17 x 9 with +48 offset. 235 x 40 will fit fine. Any wider and you will probably have to roll the fender slightly.
