Mazdaspeed B6 Flywheel
project.r.racing
Postby project.r.racing » Fri Jun 24, 2011 10:57 am
Anyone know the weight of it. Tried google and I failed.
criss
Postby criss » Fri Jun 24, 2011 12:42 pm
18lb as I remember ?????
Can anyone confirm that???
Re: Mazdaspeed B6 Flywheel
Postby 93_Clubman » Fri Jun 24, 2011 12:57 pm
criss wrote:18lb as I remember ?????
NA6 B6 OEM was 18lbs.
FWIW, believe MazdaSpeed chromoly BP flywheel is 8lbs.
Postby NitroDann » Fri Jun 24, 2011 1:05 pm
The forum 'elites' wont like this answer, but its likely more expensive than aftermarket options, and WAY more expensive than getting the stock item modified. Its also a set weight so you cant just get any weight you want.
project.r.racing
Postby project.r.racing » Fri Jun 24, 2011 2:07 pm
Thanks for the info. 3.6kg/8lbs sounds about right. The Maruha fly is that weight also.
NitroDann wrote:The forum 'elites' wont like this answer, but its likely more expensive than aftermarket options, and WAY more expensive than getting the stock item modified. Its also a set weight so you cant just get any weight you want.
Thanks for the advice, I have the option of purchasing the MS Chromoly flywheel from Japan for $250 2nd hand.
edit//
Did some more google hunting. Found 2 website with same details:-
Flywheel weight is 6.2kg. Mazda part number QEPE-11-500
gussy
Postby gussy » Fri Jun 24, 2011 4:56 pm
Where these on all MAzdaspeed Na's or just an option?
Si.G
Postby Si.G » Sun Jun 26, 2011 12:58 am
[quote]Thanks for the advice, I have the option of purchasing the MS Chromoly flywheel from Japan for $250 2nd hand.[\quote]
I am not sure I would want to get a 2nd hand flywheel - You can get a F1 Racing Chromoly flywheel that is 4.2kg for about $200 new.
Something like this ...
http://gripforce.com/store/index.php?main_page=product_info&cPath=4_126_314&products_id=410
Si
NA6 B6T
Barbagallo Raceway : Long Track 67.394, Short Track 56.755
Postby NitroDann » Sun Jun 26, 2011 1:12 am
why no second hand flywheel? Any mx5 on the planet that has its original flywheel might as well be second hand and no ones worried.
Users browsing this forum: No registered users and 172 guests
