How to tell if your clutch is on the way out?
Incognito
Postby Incognito » Tue Jun 21, 2011 2:41 pm
Is there a good test to see if your clutch is slipping?
Thanks in advance
The answer to the question of Life, the Universe and Everything is not 42..... it is MX5.
Re: How to tell if your clutch is on the way out?
Postby NitroDann » Tue Jun 21, 2011 2:55 pm
Give the car a gentle clutch kick in 4th. It should grab hard and shove you in the back. If it revs a bit and pushes softly its not ok. But if you accelerate and the tacho is moving faster than the car is accelerating that should be enough to tell you.
dave2221
Postby dave2221 » Tue Jun 21, 2011 3:22 pm
Old Dude
Postby Old Dude » Tue Jun 21, 2011 4:15 pm
Easiest way if your driving along in second put it into fourth and accelerate, because you have put the car under load ( by effectively being in to hgher gear) if there is a problem with your clutch the revs will rise with no real added speed. If its OK the revs will drop and the car may labour then slowly increase speed.
Dale 8)
MX 5 2001 Grace Green
NB8B
jerrah
Postby jerrah » Tue Jun 21, 2011 4:30 pm
I've always found driving up a hill in a tall gear is a good indicator. (high load) Revs increase without increase in speed etc as per previous instructions.
1991 MX5
mxfive95
Postby mxfive95 » Tue Jun 21, 2011 6:43 pm
dave2221 wrote:
What a pisser! Looks like the dude was attempting a burnout with the brakes on :shock: Douche
The bumper sticker on my porsche
"My other car is an mx5"
Postby NitroDann » Tue Jun 21, 2011 7:06 pm
You need to use the brakes to do a burnout.
Apu
Postby Apu » Tue Jun 21, 2011 7:17 pm
On a front wheel drive? Handbrake on, yes...but did he have his foot on the middle pedal?
rhythmstick
Postby rhythmstick » Tue Jun 21, 2011 10:53 pm
I don't see a break light on (maybe angle), so I'd say no.
This is my MX5. There are many like it, but this one is mine. My MX5, without me, is useless. Without my MX5, I am useless.
The MX5 Drivers Creed.
Incognito
Postby Incognito » Tue Jun 21, 2011 11:44 pm
Tried all of the above today, It feels ok. I cant put my finger on the burning smell though.
Postby NitroDann » Wed Jun 22, 2011 12:01 am
smells.
Coolant
Oil leaking on exhaust (diff usually)
Battery overcharging
Clutch
Brakes
Fuel
Thats about all on an mx5.
CheyneX5
Postby CheyneX5 » Wed Jun 22, 2011 12:04 am
When you say it felt ok, was it driving normally, or was there a little slip involved?
90' NA6 - Classic Red
Pamex
Postby Pamex » Wed Jun 22, 2011 9:56 am
I spotted you testing it on my mountain run today. What was with the flames out the back?
Postby 93_Clubman » Thu Jun 23, 2011 12:13 pm
Incognito wrote:Is there a good test to see if your clutch is slipping?
Incognito wrote:Tried all of the above today, It feels ok. I cant put my finger on the burning smell though.
In your Incognito-guise, we thought you were all seeing, all hearing, & all knowing! :mrgreen:
pcmx5
Postby pcmx5 » Thu Jun 23, 2011 4:35 pm
Pull the handbrake on tight, dial in 3000rpm,select 1st, pop the clutch .If it stalls the clutch is ok if if slips then you have some drama with it!
Peter.
Users browsing this forum: Google [Bot] and 38 guests
