NB8B CAI
Re: NB8B CAI
Postby NitroDann » Sun May 29, 2011 11:06 am
Theres still no point in that you linked to.
Its still sucking air from a medium pressure warm environment.
Ill say it again. Outside of the engine bay, in a high pressure area, which is either at the front of the front bar with a funnel going to it, or as close to the centre of the where the windscreen meets the window.
Locutus
Re: NB8B CAI
Postby Locutus » Sun May 29, 2011 11:02 pm
dann, the cowl style intake is difficult to do on an NB8B because the brake lines run along the top of the firewall from the ABS actuator.
Re: NB8B CAI
Postby NitroDann » Mon May 30, 2011 12:02 am
I understand that its hard to buy a cowl intake for an nb. But having said that there is no reason the opening into the firewall cant be rectangular rather than round. And brake lines are very cheap and easy to reroute.
Also an intake can be made easily by enclosing a pod filter anywhere in the engine bay. This is easiest to do with a pod filter that comes with a full enclosure.
Then run some flex pipe to a small hole neatly cut next to the radiator opening, and seal the whole thing.
Before anyone tells me this is 'stupid advice for a streetcar, not everyone races', its the only well priced genuinely working system that gets cold air and at speed generates pressure, whats more it will not increase noise at all, just like op asks for.
For proof that this will actually pressurise the intake, Mark Helmans car (for the uninitiated, he holds the wakefield naturally aspirated record by a very large margin) has a similar intake on his car that keeps pressurising itself so much it blows the seals off and the box comes apart.
I hope this helps the original poster.
aviper4u
Re: NB8B CAI
Postby aviper4u » Tue May 31, 2011 4:14 pm
NitroDann wrote:Theres still no point in that you linked to.
yea i know that, i just like how it's on the cold side of the bay. that with a duct down in the lower front bumper i think would be great unless no one does it because of water maybe?
i find it strange that there is no product that does this, closest is autoexe..........??
anyways the search continues thanks everyone
Re: NB8B CAI
Postby NitroDann » Thu Jun 02, 2011 8:21 pm
Is there a good reason you havent considered making one?
aviper4u
Re: NB8B CAI
Postby aviper4u » Sun Jun 05, 2011 11:13 am
NitroDann wrote:Is there a good reason you havent considered making one?
hmm well i am an IT guy, so not exactly the best at custom engine mods lol............
though any one know any thing about the below, first one has airbox with optional duct to grab cold air?
http://www.ebay.com.au/itm/WEAPON-R-SECRET-RAM-AIR-INTAKE-94-04-MAZDA-MIATA-1-8L-/300357820559?pt=Motors_Car_Truck_Parts_Accessories&hash=item45eeb8a08f
http://www.ebay.com.au/itm/Weapon-R-Secret-Air-Intake-Mazda-Miata-94-04-1-8L-/310235854055?pt=Motors_Car_Truck_Parts_Accessories&hash=item483b7f74e7
Re: NB8B CAI
Postby 93_Clubman » Sun Jun 05, 2011 2:55 pm
aviper4u wrote:any one know any thing about the below, first one has airbox with optional duct to grab cold air?
Secret Weapon has been around for a while - don't know if the intake engine cross pipe is worth it on an NB8, but given your search for an off the shelf solution, perhaps just buy the 'Ram Air Kit' which is available separately for US$35 for Mk 1 or US$47 for Mk 2:
http://www.secretweaponperformance.com/ ... fault.aspx
Then if you can on an NB8B, partially adopt the approach taken by MX5Chic:
viewtopic.php?f=44&t=37857&p=491970#p491970
viewtopic.php?f=57&t=37873&p=497825#p497825
Or don't by the 'Ram Air Kit', & if it's possible on an NB8B, fully adopt the above DIY approach by MX5Chic.
Re: NB8B CAI
Postby NitroDann » Wed Jun 08, 2011 1:08 am
For anybody who wants to know.
I logged air intake pressure yesterday with my hole in firewall homemade job.
Intake air temp at the manifold was only 24 degrees (it is way over 50 stock, ive seen 90).
At just 50km/h I logged 3kpa of pressure. Thats 0.44 psi of pressure.
Ie almost half a pound of boost, at just 50kph.
Ill do more logs if anyone is interested and post them.
Charlie Brown
Re: NB8B CAI
Postby Charlie Brown » Thu Jun 09, 2011 5:24 pm
There’s only one way to do it properly in an NB8B and that's the way Brian did it years ago.
See Brian’s car here and then drop him a line (bjones on this board) and see where to source it.
http://www.cardomain.com/ride/243312/20 ... x-5/page-5
aviper4u
Re: NB8B CAI
Postby aviper4u » Fri Jun 10, 2011 11:14 am
Charlie Brown wrote:There’s only one way to do it properly in an NB8B and that's the way Brian did it years ago.
that is a true cold air intake.....
though i cant help but wonder why he didnt do it completely on the intake side ? ease of wiring maybe.....
Re: NB8B CAI
Postby sliq » Fri Jun 10, 2011 11:29 am
i don't think you get the optimum gain if it was cold side.
i know on the hot side there's a hole on the chassis which allows you to bolt the down pipe and the airbox. that hole might be missing on the cold side. it's definitely a hole you don't want to be cutting out =\
Re: NB8B CAI
Postby 93_Clubman » Fri Jun 10, 2011 6:33 pm
aviper4u wrote:though i cant help but wonder why he didnt do it completely on the intake side ? ease of wiring maybe.....
As Sliq says, think you'll find it's because of the pre-existing cut-out on passenger side.
A number of the other CAI kits require MAF wires to be extended, so shouldn't really be a consideration.
Re: NB8B CAI
Postby NitroDann » Fri Jun 10, 2011 8:26 pm
The way Bjones did it seems like a pretty generic way, box a pod filter then put an intake in the mouth?
Seems normal, like hellmans car and anyone not wanting to move aircon/brake lines in an nb.
bootz
Re: NB8B CAI
Postby bootz » Wed Jun 29, 2011 12:06 am
Postby sliq » Fri Jun 10, 2011 8:29 am
Wiring doesn't need to be cut.
I don't see the big problem in cutting a hole in the coldside (behind the headlight) to replicate the hotside one. It's not in a place you would notice and I want to box it in if possible just in case the police wish to look in the bonnet.
If they want to be real bastards they can defect you for a pod filter. :roll:
Re: NB8B CAI
Postby NitroDann » Wed Jun 29, 2011 12:17 am
Hahaha. I think you will find thats the single most common defect.
Users browsing this forum: No registered users and 170 guests
