Low rent turbo MX5... ouch
zossy1
Postby zossy1 » Mon May 16, 2011 10:34 am
http://www.ebay.com.au/itm/1990-MAZDA-M ... 761wt_1139
"It runs and drives great but can be unpredictable at times on boost. (runs lean)"
:shock: :shock:
"It needs: ... an ECU capable of mapping boost levels"
Re: Low rent turbo MX5... ouch
Postby NitroDann » Tue May 17, 2011 6:59 pm
sh*t yeah, megasquirt and 550's and you got a sweet track beast for 5 grand? oh except for brakes cooling diff 5 speed....
etc etc etc
red devil
Postby red devil » Tue May 17, 2011 9:25 pm
It's got an LSD :wink:
I dont care that my laces aren't fat or that I'm not even close to flush and I certainly don't want to be the illest!
bootz
Postby bootz » Fri May 20, 2011 2:00 am
Oh come on, all the gear he has added should add up to nearly 4K. So basically you are getting the car for FREE!
i think a half finished turbo for this money is good (subject to vehicle inspection and engineering). 1K for tuning and you will be set.
I don't think he is selling it registered so that might cause problems. :? :?
zossy1
Postby zossy1 » Fri May 20, 2011 12:17 pm
Think eBay... This was done on the cheap. I'm not sure those bits are worth anything like $4k... He didn't even put the fans back in! My guess is his generic eBay FMIC plumbing and turbo outlet piping got in the way... :(
Tedsmx5
Vehicle: NA8 - Supercharged
Postby Tedsmx5 » Sat May 21, 2011 4:51 am
It's mostly red that's a plus :P :NA6:
Ted
Why didn't I buy one years ago?
NA8 Ceramic coated headers, Hi flow cat, 2.5”system, M45 SC 150/62.5 8psi, Dual TB, IC & Adaptronic ECU.
jerrah
Postby jerrah » Thu May 26, 2011 9:37 am
Didn't sell.
It has HEAPS of room to put the fans back in from the pictures I can see. It would have taken him 5 minutes to put them in so I'm not sure why he didn't.
Possibly a rising rate fuel regulator on the firewall behind the turbo? Can't have been run long like that it has an unshielded washer bottle in the stock location. :D
Manifold looks like a tacotaco ebay special, but at least it's not one of those crackandfail 'stainless' jobbies.
1991 MX5
zossy1
Postby zossy1 » Thu May 26, 2011 2:20 pm
jerrah wrote:Didn't sell.
Might have removed the fan switch sensor to plumb the turbo feed. Who knows - it's a backyard special ;)
Users browsing this forum: No registered users and 99 guests
