hi there.
installing an adaptronic E420c in my na6.
i am told that i need a variable tps.
i also hear from other sources that this can be done diy?
if its easier or better even, replacing is also on the cards.
anybody know where i would get one of these "variable tps's"?
NA6 Variable TPS
NA6 Variable TPS
The Secret Weapon
- timk
Re: NA6 Variable TPS
I used a BMW variable TPS on my NA, the write up is here:
http://ozmx5.com/viewtopic.php?f=4&t=27
http://www.efihardware.com/products/880 ... twin-wiper
You can use this to fit a variable TPS to the std throttle body. Correct shape for shaft, will need some drilling and thread tapping but if you can't do that then maybe you should think twice about what your doing.
Terry
Terry
