The carbon fibre time attack/superlap MX5 NB twins blog
bootz
Re: The carbon fibre time attack/superlap MX5 NB twins blog
Postby bootz » Fri Apr 29, 2011 11:20 pm
I know what you are doing is awesome but what about a street machine with just CF panels like your one but a bit more restrained. Perhaps some subtle wheel arch flares and moulded in front and rear lips.
I am sure there are people mad enough or rich enough to want to do it. 8) 8)
deviant
Postby deviant » Sat Apr 30, 2011 2:53 am
bootz wrote:I know what you are doing is awesome but what about a street machine with just CF panels like your one but a bit more restrained. Perhaps some subtle wheel arch flares and moulded in front and rear lips.
I would love to just do the easily removable bits in CF....which is quite a lot when you think about it. Front and rear bumpers, rear garnish panel, boot lid, hard top, bonnet, front wings and the doors. Just leave it all the stock shape for ease of moulding and replacement should something get broken.
lightyear
Infinity & Beyond
Vehicle: NA6 - Turbo
Postby lightyear » Sat Apr 30, 2011 8:51 am
It can be done, come and see me when you win lotto or save a few grand.
The reason i want to keep it simple and not have cables or rods running thru the doors is so i can foam fill them. That way they will act as a huge crush box.
mr2 spyder
Postby mr2 spyder » Sat Apr 30, 2011 8:34 pm
You want to be carfull when doing the foam, maybe even clamp the moulds back on you dont want to blow them up like a balloon . and make sure no water gets in or your weight saving goes out the window. that foam loves to soak up water.
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Thu May 12, 2011 12:59 pm
any goss?
lightyear
Infinity & Beyond
Postby lightyear » Thu May 12, 2011 3:05 pm
I am moving house over the next 2 weeks, so i have been busy packing. Everything has to go into storage for a week, so i have to move everything twice :roll: . That includes all the house stuff, the "wrecking yard" of car parts and gear, as well as all the fibreglass moulds, and c.f gear. A lot of stuff to pack and move for 1 person.
I had the rep out and he told me the best way to do the foam core. And it will be fully sealed so no water can get in.
lightyear
Infinity & Beyond
Postby lightyear » Sun Jun 05, 2011 9:15 pm
No progress on the car as it is still in storage. But i have moved house and got to work ripping down the old garage.
Garage as we got it 3m x 9m, had a family of rats, no floor or windows, asbestos cladding, and plenty of rubbish.
Poured a new slab, had to barrow it, shovel it, screed it and finish it myself. Fark'n hard work. I did it in two stages to break up the work.
Welded up the new garage frame, and with some help i now have them standing.
mr2 spyder
Postby mr2 spyder » Sun Jun 05, 2011 9:38 pm
Great work on the garage too.
Postby Okibi » Mon Jun 06, 2011 12:19 am
Indoor pool! :mrgreen:
Postby Okibi » Thu Jun 09, 2011 8:48 pm
Great to see you're finally on the forum MX5T! :mrgreen:
lightyear
Infinity & Beyond
Postby lightyear » Thu Jun 09, 2011 9:39 pm
I worked out the weight to around 820kg's originaly, but since then i have found a few kilo's here and there. So should get it under 800kg's.
nfs13b
Vehicle: 10AE - Turbo
Postby nfs13b » Sat Jun 11, 2011 3:23 pm
lightyear wrote:I worked out the weight to around 820kg's originaly, but since then i have found a few kilo's here and there. So should get it under 800kg's.
wish I could get mine close to that weight......
MX5 13B - NFS Racing
PRO-MX5 PB 7.46 @ 179mph & 1.07 60ft
lightyear
Infinity & Beyond
Postby lightyear » Mon Jun 13, 2011 9:58 am
How much does yours weigh? The bar work in yours would add close to 100kg's i would think. The entire bodywork on mine will weigh about 19kg's including the doors, roof, etc.. About the same as the oem hardtop.
nfs13b
Postby nfs13b » Mon Jun 13, 2011 10:22 am
lightyear wrote:How much does yours weigh? The bar work in yours would add close to 100kg's i would think. The entire bodywork on mine will weigh about 19kg's including the doors, roof, etc.. About the same as the oem hardtop.
Mine weighed 745kg without the gearbox, engine internals, clutch and fluids....
lightyear
Infinity & Beyond
Postby lightyear » Sat Jun 18, 2011 9:08 pm
Shed is up now, electrician is coming tueday, and then i can put the lining in and try and fit everything in.
The yellow mx5 is the new temporary track car.
