NA6 and NA8 brake calliper size
plohl
Postby plohl » Mon May 09, 2011 1:48 pm
Haven't been able to confirm anything so thought i would ask.
NA6 and NA8 brake callipers are not the same are they? The NA6 take a smaller pad? or is it the same calliper with a different mounting bracket?
plohl
pepejesus
Re: NA6 and NA8 brake calliper size
Postby pepejesus » Mon May 09, 2011 3:18 pm
My understanding is they are slightly different although you can mount an NA6 caliper to an NA8 sized disc by using the NA8 brackets.
Barbagallo long: 70.488
Barbagallo short: 58.999
plohl
Postby plohl » Mon May 09, 2011 3:46 pm
So it would be correct to assume the pads are different? that should have been my question from the beginning.
plohl
project.r.racing
Postby project.r.racing » Mon May 09, 2011 4:10 pm
go on the bendix website and type in the 2 models. see what the results are.
mazdatenfive
Postby mazdatenfive » Mon May 09, 2011 4:11 pm
plohl wrote:So it would be correct to assume the pads are different? that should have been my question from the beginning.
Pads and discs are larger on NA8.
plohl
Postby plohl » Mon May 09, 2011 4:59 pm
Thanks guys! :beer:
plohl
Users browsing this forum: No registered users and 329 guests
