Haven't been able to confirm anything so thought i would ask.
NA6 and NA8 brake callipers are not the same are they? The NA6 take a smaller pad? or is it the same calliper with a different mounting bracket?
NA6 and NA8 brake calliper size
- plohl
plohl
plohl
- pepejesus
Re: NA6 and NA8 brake calliper size
My understanding is they are slightly different although you can mount an NA6 caliper to an NA8 sized disc by using the NA8 brackets.
Barbagallo long: 70.488
Barbagallo short: 58.999
- plohl
So it would be correct to assume the pads are different? that should have been my question from the beginning.
plohl
plohl
- Vehicle: Non MX-5
go on the bendix website and type in the 2 models. see what the results are.
- plohl
