Sonax Wheel rim coating
Sailor
Postby Sailor » Thu Apr 21, 2011 10:20 am
Anyone using Sonax products?
I 'm considering using the wheel rim coating on a new set of wheels, after some feedback.
http://www.sonax.com.au/
Rob
Re: Sonax Wheel rim coating
Postby Mr Morlock » Sat Apr 23, 2011 11:24 am
have not tried it Sailor but it looks like it would do the job. I imagine Penrite would not sell a dud product.
lukearama
Postby lukearama » Sat Apr 23, 2011 11:29 am
Started using Sonax... They are German approved for Porsche apparnetly. Happy with the results. Think you will be fine.
Apart from Mazda............ trust nothing else...
Sailor
Postby Sailor » Sat Apr 23, 2011 6:38 pm
Thanks guys.
Will pull the wheels out next weekend and treat then prior to fitting tyres.
Rob
Sailor
Postby Sailor » Tue Jul 05, 2011 12:50 pm
Finally got around to cleaning and treating the wheels.
Cleaner works outstandingly!!
Don't be put off by the old style hairdresser smell or the fact that your wheels turn BRIGHT purple.
Make sure they're BONE DRY and rinse thoroughly with high pressure.
The Wheel rim coating is easy to apply to the BONE DRY, clean wheels.
Spray on and spread evenly with a cloth dampened slightly with the spray.
DON'T allow it to begin drying before spreading as it leaves spot which need to be recoated and rubbed out.
Do one wheel at a time.
Leave to dry for a couple of minutes and lightly polish the haze left with a soft cloth.
Time will tell how effective it is at repelling brake dust but in the meantime, the wheels look great.
Rob
Sailor
Postby Sailor » Tue Jul 12, 2011 6:39 pm
UPDATE
This stuff absolutely positively without a shade of a doubt WORKS!!!
The car has EBC Redstuff pads which are probably the dustiest I've ever used, dríven for a week,
went out with a WHITE cloth and got just a trace of black on the cloth.
Normally the wheels would have looked gunmetal by now.
Rob
