1.7 all motor
criss
1.7 all motor
Postby criss » Thu Apr 14, 2011 3:26 am
i reckon my engine will need a rebuild soon,
anyone got any information about what we need for a 1.7 motor???
criss
1.7 all motor
Postby criss » Thu Apr 14, 2011 1:37 pm
Mine is a na6, Cus the engine might need a rebuild, so better just stroke it at the same time?? I know it's been done in US before, but dun know What will beinvolve , b6 engine just doesn't get the bless like the Bp engine, which got a stroke kit off the shelf =[
Re: 1.7 all motor
Postby Jeo » Thu Apr 14, 2011 3:12 pm
From memory there's a few decent thread on miata.net on the subject. I'd suggest having a look there.
jerrah
Re: 1.7 all motor
Postby jerrah » Thu Apr 14, 2011 3:57 pm
I did a google search and found this thread of someone building a 1.7: http://clubroadster.net/vb_forum/showthread.php?t=18582
1991 MX5
yuge
Re: 1.7 all motor
Postby yuge » Thu Apr 14, 2011 5:49 pm
i am actually in the process of building a 1.7L motor.
I bought Toda Hi-comp pistons which were 3mm oversize. Giving a total of 1722cc
Usually wouldnt have needed to resleeve, but my engine builder found air bubbles after machining out the block.
So got two new sleeves.
Re: 1.7 all motor
Postby NitroDann » Fri Apr 15, 2011 8:13 pm
Criss I could have just PMd you back with this info, but the block wont handle a 3mm overbore AND boost, its one or the other.
criss
Re: 1.7 all motor
Postby criss » Fri Apr 15, 2011 11:43 pm
jeo&jerrah. thank for that guys=] found that very useful
yuge, anything you put in the engine as well??? may i know whats your plan wif the engine?? going hi profile cam and itb?
dann, didn't get your pm regarding to this,
but i do get the pm regarding to the bsb issue=]
yuge
Re: 1.7 all motor
Postby yuge » Sat Apr 16, 2011 1:39 pm
pm'd
Matty
Re: 1.7 all motor
Postby Matty » Sun Apr 17, 2011 1:12 pm
To the people doing this or wanting to - Why?
Not a facetious question, just curious for your motivations to do this rather than the alternatives that are much easier, cheaper and give better results.
broady
Re: 1.7 all motor
Postby broady » Sun Apr 17, 2011 2:14 pm
criss, your car is a street car, right? If you want a bit more grunt, why not transplant a 1.8? Rebuilding and boring/stroking the 1.6 will cost a lot.
人馬一体 NA8
6/5/2010
Re: 1.7 all motor
Postby NitroDann » Sun Apr 17, 2011 3:45 pm
Matty wrote:To the people doing this or wanting to - Why?
And to broady,
Have a drive of my all motor 130rwhp 1.6, Its as fun as hell. And maintenance free.
And an exhaust and intake more than evens up the 1.6 vs 1.8 battle. why go to all the effort of a swap?
broady
Re: 1.7 all motor
Postby broady » Sun Apr 17, 2011 4:07 pm
And to broady,
I don't doubt it at all. 1.8 swap is well documented and not a great amount of effort.
人馬一体 NA8
6/5/2010
yuge
1.7 all motor
Postby yuge » Sun Apr 17, 2011 5:21 pm
My main reason for doing up the 1.6l is that I already had a set of itb sitting at home. Also a set of headers. So didn't want to get new headers or remake a set of inlet manifolds to match the itb.
criss
1.7 all motor
Postby criss » Sun Apr 17, 2011 7:54 pm
It's true that turbo is a easier and cheaper option to increase the power, but even they can both make foe example 150 atwhp, they still feel different, and I like the non turbo feel, also If I go to the turbo route, I have to ditch all the effort I put on the car, I just dun want to see this happen=]
And I believe my 1.6 should be able to keep up with a 1.8, so 1.8 swap is not an option atm, unless I found a cheap one, and I will still do the exact same thing to it, just my 2.2c( gst included)
I might sound silly, but how can u say no to a done up engine with instance respond =]
Matty
Re: 1.7 all motor
Postby Matty » Sun Apr 17, 2011 10:23 pm
criss wrote:It's true that turbo is a easier and cheaper option to increase the power, but even they can both make foe example 150 atwhp, they still feel different, and I like the non turbo feel, also If I go to the turbo route, I have to ditch all the effort I put on the car, I just dun want to see this happen=]
I don't disagree with your last sentence. But I've been down your route and I know it is difficult to stop emotional attachment getting in the way of the end result.
Either swapping in a BP, or selling up and buying a NA8 (which nets you a whole host of other goodies like clutch, diff, brakes, synchros, power steering, newer car, etc) is by far the best option. You screw around with the motor less, you'll have more torque, more reliability (less custom parts), less need to spend time and money tuning it. And if you do tune up a 1.8 you will be that much further ahead again. The cost of selling your exhaust and fitting a new one is pittance in comparison to what you are talking.
If I were you I'd write up a spreadsheet mapping out the alternatives, and all the costs involved, as well as assesing the end result (in kW). Then walk away and think on it for a while before acting.
