Wazman's NB8a
Re: Wazman's NB8a
Good work - I think you asked on garage thread about solid lifter, but since you are further along then me, where did you end up getting the lifters and shims from? I assume you had to go through the pain of test fitting, measuring and then working out the shim thinkness for each valve?
Also where did you get you oil pump from - not seen any on the usual sites?
Si.
Si.
NA6 B6T
Barbagallo Raceway : Long Track 67.394, Short Track 56.755
Re: Wazman's NB8a
Some bling here Si
http://boundaryengineering.com/drupal/node/34
- RawSouth
- wazman
Re: Wazman's NB8a
Hi all,
Been a while since i've posted.
The T28 i fitted had a little to much shaft play and started to sing at full noise (thrashing) so i ditched it and bought what i was too tight to buy the first time!
a Garret 2871r with the small rear housing....... yay 220 rwkw with no cams.
Every thing just bolted straight up as this is the "two bolt" intake type. A direct swap for nissan s14- s15
Pic bellow is the the T28.......note the Bent fin
Some bushes are in....
New nardi deep corn 330mm and triple dice shifter that i got in Japan......New hydro handbrake lever too...stainless (dosn't flex)
Some thing ive wanted since i bought the car...... Roadster sill plates ! yay !
ilovedrift.com
- wazman
Re: Wazman's NB8a
and.......... i had a little mishap at the drift demo at the TOPGEAR LIVE FESTIVAL
It was a tight little track and one mistake and you had no where to go.......except up a gutter
Luckily i only bent the rear lower control arm bolt (the long one in the knuckle end) ....just replaced that and away i went.....lucky i have 3 sets of wheels to
ilovedrift.com
- wazman
Re: Wazman's NB8a
I got a new rear bumper.....JDM one with roadster badge......also big ugly JDM number plate hole......meh
For those of you that dont check the NB wheel pic thread......
With the 16's i was running 4.3 degrees of camber on the rear....... which ment that i would drift through a brand new pair of tyres in 4 laps at winton ! mainly just wearing the edges off though..leaving 60% tread in the middle that i would never touch.......
So on got the much less agressive 15x8 +25 sportmax thingys......( i forget their name).
Tyres are now 195 50 15 neuton's on the rear (they smoke like crazy, every drifter loves em)
I have straightened up the camber on the rear as much as the standard camb bolts will allow...... but i want neg 1deg of camber so i'll be modifying the rear arms soon....
I can also replace my munched front guards now without fear of the wheels/tyres catching them and pulling em in again...
old alloy vs new stainless hydro lever....
I tried to find my dyno sheet to post it up but i seem to have misplaced it.... stay tuned , i'll find it ....
ilovedrift.com
- wazman
Re: Wazman's NB8a
Testing TOPGEAR stort track at the live festival
start watching from 2:30 min's...... just waiting around at the start.
ilovedrift.com
Re: Wazman's NB8a
nice driving man (y)
- gobsmax
Re: Wazman's NB8a
sick vid!
Red '91 NA6 (R.I.P.)
Black '07 NC PRHT (R.I.P.)
Gold '98 NB8A (SOLD)
Soul Red '15 ND 1.5 GT
- slimx
- Vehicle: NB8B - Turbo
- RawSouth
Re: Wazman's NB8a
Just read this thread, awesome work.
Pretty sure you have been in my old car, i did a vic drift prac day at shepparton, you were the controlled handbrake instructor?
- tobias
Re: Wazman's NB8a
deanb90 wrote:Just read this thread, awesome work.
What car were you in? I was there with my mates ae86, was a good day very cold though
Re: Wazman's NB8a
^ Grey S15 autech on green P's. Was cold but so fun.
- wazman
Re: Wazman's NB8a
New front bar..... Being small the standard mx5 NB8a front bar has a small mouth.
So I decided to get something to help keep the temps down.
ilovedrift.com
