How much would it cost (roughly) to get an engine replaced in an NA, with a standard replacement engine.?
$1000 for engine?
how much for labour?
engine replacement cost?
- nissky
- zossy1
Re: engine replacement cost?
nissky wrote:How much would it cost (roughly) to get an engine replaced in an NA, with a standard replacement engine.?
$1000 for engine?
Depends on the shop. It isnt that hard but takes a while - 6-8 hours assuming all goes well. Maybe more.
Multiply that by your standard $80-$120/hr rate.
- Vehicle: Non MX-5
$1000 = labour + fuilds + misc.
Ill fit my engine to your car for much less than that. I have a for sale thread and there I offer to fit the engine also.
Can you drive to newcastle?
- nissky
Im just doing research dan,
deciding between buying a good NA versus buying one that is going to need major work.
Im a mechanic.
But even if i werent and I wanted a weekend car Id definately buy a blown one.
Your gonna end up putting forgies in it anyway so why start with a running engine etc.
Not to mention all suspension bushes and shocks etc will be replaced, half the interior. etc etc
- zossy1
NitroDann wrote:Your gonna end up putting forgies in it anyway so why start with a running engine etc.
Win
Sadly my forgies will need to wait until I get itchy and turn the boost up too high on the stock internals... ;)
supertech pistons plus m tuned rods and oil pump gears equals 8500rpm and 400 HP with enough boost, so why wouldnt you? For the 1200 it will cost anyways.
- zossy1
NitroDann wrote:supertech pistons plus m tuned rods and oil pump gears equals 8500rpm and 400 HP with enough boost, so why wouldnt you? For the 1200 it will cost anyways.
^^ This, plus a shagged 1.8 to rebuild, and I can do both
My thought patterns are closer to yours than you think, Dann!
sorry to thread jack, hows the build going anyways? your build thread suggests your not boosted yet but you just suggested you were?
- zossy1
NitroDann wrote:sorry to thread jack, hows the build going anyways? your build thread suggests your not boosted yet but you just suggested you were?
This car isn't boosted yet - not even painted yet
But when it is, it won't be my first boosted mx5!
Users browsing this forum: No registered users and 112 guests
