URGENT - NA speedo cable to NB 6 speed, how to ?
- jerrah
Re: URGENT - NA speedo cable to NB 6 speed, how to ?
I just put the speedo drive from the NA6 box into the 6 speed from memory?
1991 MX5
Interesting topic as i just purchased a 5 speed NB gearbox for my NA6.
Is it possible i may end up having the same problem when i try to install it? or is it specific to the 6 speed
I don't see why you can't swap them out?
I had an NA6 box in mine once upon a time and all we did was swap the sensors.
- jerrah
I have a NA6. Took out the NA6 box and put in a NB 6 speed. Put the speedo sender from the NA6 box into the NB 6 speed, and yes spliced the wires as you have said.
I have a 6 speed and a 4.1 Torsen. I've checked my speedo vs a GPS and it's nearly 100% accurate whereas it was a margin out with the 4.3 open and the NA6 5 speed. Pretty sure it read high in the factory configuration.
1991 MX5
Also a bit of info from RussellB here:
viewtopic.php?f=29&t=37365&p=485590&hilit=#p485590
