Hi guys,
I'm looking into buying an na6 and I've found one that's caught my fancy.the only issue I have with it is that it judders when I get off the throttle in second gear after moderate acceleration,along with a whirring sound in second whenever I get off the throttle. Added to that when I put the throttle all the way to the floor at 2.5k rpm in any gear basically nothing happens for 4 odd seconds till it hits 3.5-4k and actually starts to accelerate properly. I know I should get a mechanics test done but I need to get it locked down by tomorrow so times against me,and I was wondering if anyone had ideas about what the possible isse is?
Possible gearbox issue?
- zossy1
Re: Possible gearbox issue?
Take my advice and look elsewhere - unless the car is stupidly cheap. There are too many good cars out there at the moment at good prices.
- NZMiata
If it's an early NA6 the engine lag could be a symptom of the short nose crank problem. Replacing the engine is the usual fix so I would probably say no to this particular car.
Red 1994 MX-5
zossy1 wrote:Take my advice and look elsewhere - unless the car is stupidly cheap. There are too many good cars out there at the moment at good prices.
+1 - never let time constraints dictate purchases unless you know exactly what the problem is, how much it's going to cost, & the item is priced accordingly.
Users browsing this forum: No registered users and 123 guests
