bensale wrote:Lee, the car with panel modifications also has no soft top... And also has a cf hardtop fitted so in that case he has made an aprox 17kg weight saving...
Which is why the Classification officer gave you an exemption to run without your soft top until the Motorsport meeting this week which will clarify the ruling on hard tops & soft tops.
bensale wrote:In addition to this it looks like i was in a good position to win a sheep station after all, the clubs rookie of the year award which I am probably out of the running for now.
Rookie of the Year is given to the competitor with the most points in their first year of competition with the club. Points can be scored in multiple classes.
So you are still eligible for this, and most likely will still win it..
As I understand it, the protests were lodged due to the fact that your 'standard' na6 was significantly quicker 'in a straight line' than all other std NA6s and most of the standard NA8s & NB8's in the club, not because of the impressive lap times you posted. They just drew attention to yourself.
The subsequent investigation highlighted the fact that your car was running with 7 mods (ignoring soft top) when you are only permitted 4, hence the reclassification to modified.You also only specified 2 mods on your entrant statement, which wasn't consistent with what your car actually had.
bensale wrote:And i agree! It appears that my ecu, cat, extractors, compression and cams are all standard hey?
But I still need to put it on a dyno...
The absence of these items makes the cars straight line speed even more surprising, hence the requirement for a dyno...
The 2010 Vic club motorsport rules state '
Competitors found to be in blatant contravention of the class rules at an event will be
automatically disqualified from the event, and may be disqualified from the championship.'
The motorsport captain would have been within his rights to exercise this clause however, chose not to due to the helpful and honest manner you showed, and simply had your car reclassified into the class that it
correctly belongs in in its current condition.
Surely you can't be too annoyed with this approach....
