My NA has a small phillips head screw under the knob, the fan-ac switch just pulls off.
Ted
Heater Control Knob Removal
- Tedsmx5
- Vehicle: NA8 - Supercharged
Re: Heater Control Knob Removal
Why didn't I buy one years ago?
NA8 Ceramic coated headers, Hi flow cat, 2.5”system, M45 SC 150/62.5 8psi, Dual TB, IC & Adaptronic ECU.
- Hammer
Don't they just pull out? Loop a string behind it and try pulling it straight out. If it won't budge, give MX5 Mania a call. I'm sure AJ or Dave can advise you how to do it.
- xmx106
A quick google and the miata net forum, mentions very small philips head screws that require a jewelers screw driver,as per the ones needed to fix your glasses. i dont have the car handy at the moment to have a look, but i always though there was a screw involved somewere. Dont the new chrome knobs give you a similar screw hole underneath ?? obviously not !!
Quote from miata net:
You need a jewelers screwdriver to get the little screws out of the bottom of the sliders. (Don't drop them, they are really tiny)
1990 NA eunos roadster for me, 2007 NC roadster for the misses, missed out on the NB?
- marcusus
From memory they just pop off. I took mine apart before (also an NB8A) and I don't remember having to use a screwdriver to remove screws. Don't quote me on that though, because that was a good 4 odd years ago.
- 7Hazi
I just checked on my NA - There are small screws under the 3 knobs that slide (temperature, etc). I couldn't see anything on the actual main dial though - I tried pulling the crap out of it and it wasn't going anywhere
(I currently have chrome ones and I am trying to go back to OEM
