Hello,
Can anyone tell me how to remove the above wheel
Thank you
Michael
How to remove original steering wheel on late NA8 ??
- Hammer
Re: How to remove original steering wheel on late NA8 ??
Here's a pictorial step-by-step guide on how to remove the dashboard of an NA, taken from miata.net.
Check page 6 for the steering wheel removal? Although this shows the Nardi wheel (not the Momo).
http://www.miata.net/garage/DashRmv_89_93.pdf
- Benny
Once you are at the point where you are undoing the centre nut on the wheel, please make sure that you leave this nut on for a couple of turns, otherwise, when you do finally get the wheel to budge, it may end up bashing you in the face and removing a couple of teeth!
It won't want to come off easily, and you will need some force to pull it off the hub.
- de Bounce
Benny wrote:Once you are at the point where you are undoing the centre nut on the wheel, please make sure that you leave this nut on for a couple of turns, otherwise, when you do finally get the wheel to budge, it may end up bashing you in the face and removing a couple of teeth!
Totally agree with leaving the nut on.
The wheel spline is generally on a taper. Once they move they come totally free similar to a ball joint.
When pulling on the wheel, I found applying extra force to one side then the other and rock/flex the wheel it should pop loose.
Alternative is to use a steering wheel puller.
