Which plug leads?
Re: Which plug leads?
Postby Mr Morlock » Thu Mar 31, 2011 7:28 pm
PS the link - in good faith- does not apply to your car- your car is a NBP2
Postby manga_blue » Thu Mar 31, 2011 8:09 pm
Actually the link applies to all NA and NB motors. It correctly details the biggest risk when changing timing belts - poor refitting of the main pulley. If your mechanic got the timing wrong then did he also mess this up? Take the photos and talk about it.
narcoticx2
Postby narcoticx2 » Fri Apr 01, 2011 9:38 am
Well the car is at the mechanics now.
I am really quite concerned that the issue wont be resolved because it was absolutely fine on the drive in this morning.
The belts are being tightened to eliminate belt whine so I suppose that's a good thing.
2001 NB8B - Supreme Blue - Hardtop - Unmodified
Postby 93_Clubman » Fri Apr 01, 2011 11:07 am
narcoticx2 wrote:...it hasn't always felt that way, it started a week or two after it was serviced.
So, it ran fine for a week or two after the service during which the timing belt was replaced?
narcoticx2
Postby narcoticx2 » Fri Apr 01, 2011 11:15 am
Well I started to really notice it about then.
Postby 93_Clubman » Fri Apr 01, 2011 11:24 am
It sounds like something that occurred after, or deteriorated to a point where it became noticeable following the service. Good luck today - hopefully they can sort it.
narcoticx2
Postby narcoticx2 » Fri Apr 01, 2011 11:30 am
93_Clubman wrote:It sounds like something that occurred after, or deteriorated to a point where it became noticeable following the service. Good luck today - hopefully they can sort it.
Thanks, yeah I don't mind if it's something that occurred or surfaced as a result of the service (new spark plugs causing old coil packs to act up maybe? or the battery starting to have issues?) and I'm prepared to pay for their services should it be that. I just want my car to be back to how it was!!
narcoticx2
Postby narcoticx2 » Fri Apr 01, 2011 4:14 pm
Okay well I got a call from my mechanic who's been over the entire car, checked everything and can't find anything wrong with it in terms of the lack of power. I did send him the link re the crank bolt and he double checked everything to do with that.
Guess we will have to wait and see if it manifests itself again...
At least I wont have any more belt whine!
de Bounce
Postby de Bounce » Sat Apr 02, 2011 7:11 am
As you get use to something your memory fades as to what was the norm.
It might be worth doing a back-to-back test with another NB8B!
Motorkhana Video
Users browsing this forum: No registered users and 88 guests
