cooling system temp
- rossint
Re: cooling system temp
No, it's an OEM Mazda one. It is possible that my gauge reads about 10deg out which would give an 80-90deg range between moving and stationary temps. I'll have to do some tests to see. I did notice the car ran cooler when I removed the AC condensor from in front of the radiator which leads me to believe the thermostat is not just open or closed as more airflow through the radiator = lower temps.
- zossy1
rossint wrote:No, it's an OEM Mazda one. It is possible that my gauge reads about 10deg out which would give an 80-90deg range between moving and stationary temps. I'll have to do some tests to see. I did notice the car ran cooler when I removed the AC condensor from in front of the radiator which leads me to believe the thermostat is not just open or closed as more airflow through the radiator = lower temps.
The thermo isn't drilled? Is your heater core routing as per OEM?
Just checked Mazda's tech data. OEM thermostat for both NA6 and NA8 is two stage wax. Opening temp for the sub is 83.5 - 86.5 and for the main 86.5 - 89.5.
There's always modest flow through the heater core, even when the thermostat is shut. There's also a trickle through a hole drilled in the thermostat plate to assist thermostat operation by getting some warm water flow over it.
- rossint
zossy1 wrote:rossint wrote:No, it's an OEM Mazda one. It is possible that my gauge reads about 10deg out which would give an 80-90deg range between moving and stationary temps. I'll have to do some tests to see. I did notice the car ran cooler when I removed the AC condensor from in front of the radiator which leads me to believe the thermostat is not just open or closed as more airflow through the radiator = lower temps.
Standard off the shelf thermo and the heater has not been modded at all, although I've been thinking about bypassing it as I never use it.
- zossy1
manga_blue wrote:Just checked Mazda's tech data. OEM thermostat for both NA6 and NA8 is two stage wax. Opening temp for the sub is 83.5 - 86.5 and for the main 86.5 - 89.5.
Certainly seems like Ross's car is running cool, if his gauge is accurate. Or the gauge may be out as he says.
rossint wrote: I've been thinking about bypassing it as I never use it.
You can bypass the heater but FFS don't stop the flow. That's an integral part of the cooling for the back of the head.
- rossint
zossy1 wrote:Certainly seems like Ross's car is running cool, if his gauge is accurate. Or the gauge may be out as he says.
I might check the temp of the radiator hose against what the gauge says at some point, should give some idea of how accurate the gauge is. To be honest I never really pay much attention to the actual numbers and more what the gauge is doing relative to what the cars doing.
I haven't looked into bypassing the heater yet, won't be doing anything until I've done a bit of reading.
- zossy1
"Racer reroute" for the heater core, "coolant reroute" for the engine
Google these or search m.net or mt.net and you will be apples
- Steampunk
on tuning runs around sept-oct, at night, I'm getting 86-87 deg C from standard sensor at the back of the engine. BeGI re-route, auto NA radiator, standard everything else.
I also have an aftermarket temperature sensor just after the thermostat.
From memory the thermostat opens about 180"F 82"C.
When sitting at the lights on really hot days the temp can rise to 210"F 99"C which is when the thermo fans kick in and the temperature starts to drop.
I remember Inf3ctor had temperature gauges with peak hold and he was seeing some pretty high temperatures with the stock radiator on his NB (dríven hard).
- Guran
- Vehicle: ND - 1.5
What are you guys using to measure the coolant temperature? If it's a thermocouple, are you applying cold junction compensation? It's a common mistake with thermocouples and can account for inaccuracy in the readings.
I have a new VDO mechanical water temperature gauge in the radiator top hose, and on the road it generally hovers around 70*C, and on the track it doesn't go over 80*C. Both with constant flow. If I am stopped for 5mins or more then it will jump up to 90*C or so, and the fans will come on.
- jerrah
My car hovers around the low 80's unless I'm sitting still in traffic where it will creep up to the low 90's. I have a coolant reroute.
1991 MX5
I see high 90's regularly. 110 strapped up a mountain. Closed course of course.
Users browsing this forum: No registered users and 96 guests
