Andy's MX5 Race car
Andy's MX5 Race car
Hi all, just thought I'd post about my car I'm building.
It's an NA MX5, started life as a 1.6, but then I upgraded to a 1.8.
Now it's getting a 1.3 - but a 1.3 without pistons!
The aim is to enter it in Superlap / WTAC this year.
Currently it's getting the engine put in. After that, MX5Mania will be doing the brakes, suspension, wheels and tyres, Bond Roll Bars will be doing the roll cage. The current plan is to pull the engine out and build it a bit more strongly before the comp.
Here are some pics of the conversion in progress:
- gobsmax
Re: Andy's MX5 Race car
subscribed
Red '91 NA6 (R.I.P.)
Black '07 NC PRHT (R.I.P.)
Gold '98 NB8A (SOLD)
Soul Red '15 ND 1.5 GT
- orx626
- Vehicle: NC - Rotary
Best of luck with the build Andy!
Hope to see you at Superlap!
Awse, loads or rotary fans here just not too many conversions. Thanks for deciding to share with us, can't wait to see more.
Thanks guys! Danny: I just subscribed to your thread, your project looks great and awesome workshop! I was considering the Renesis engine but then I thought, bang for buck I'd probably be better off with a peripheral exhaust port rather than a side exhaust port engine. I do love the Renesis engine though; so smooth!
My next step it to take a trip out to the guys putting the engine in for me with a few exhaust manifolds and work out what will fit with the steering column...
Engine in, currently fabbing exhaust manifold and all the other annoying little things!
Also, http://racecarparts.com.au helped me out with a seat! Score!
A few more pics! I don't know what I'll do about the bumper since the tailpipe has moved to the other side through the muffler change. Also not too sure where the wastegate plumbing will go!
Cheers all!
Andy
Cheers all!
Andy
I get her back later this week, then for fun with wiring!
- Tedsmx5
- Vehicle: NA8 - Supercharged
Is the intercooler big enough
Ted
Ted
Why didn't I buy one years ago?
NA8 Ceramic coated headers, Hi flow cat, 2.5”system, M45 SC 150/62.5 8psi, Dual TB, IC & Adaptronic ECU.
- Vehicle: NA6 - Turbo
Love the build, make sure you post some vids when its all done
http://www.facebook.com/purefabcustom
EFR6758 run-in tune 259hp atw on 10psi pump 98 dyno dynamics
E85 tune - 445hp @ wheels 17psi
Hey i have a carbon vented bonnet here you can have. It is in two halves at the moment [skin and frame] it may be too light even? Have it sitting in the moulds at the moment so can be stuck together easily. I am in penrith where are you?
That looks like the biggest possible turbo you can fit under the hood of an NA without cutting up the hood:
- it's almost as big as the rotary engine!
Hi all, the wastegate actually scrapes on the bonnet a bit I've discovered!
Sorry that the video is so dark, I was just so excited after I got her running that I had to video it!
http://www.youtube.com/watch?v=_hCHTW71NXU
It's only running on the factory ECU at the moment, idles really rich, rich-lean hunts badly when I connect the narrowband output from my MTXL into the factory ECU (just stays rich in open loop mode), and goes really lean and misfires when you put your foot down. So next step is obviously to put on an ECU and tune it!
It's going into MX5Mania on Monday for suspension / brakes / wheels so I guess after that's done I'll get to installing the ECU.
Cheers!
Andy
Cheers!
Andy
- PaulF
Definitely looking forward to seeing more of this!
Mark Boxer from Hoon Media did a video for me!
