Hi guys,
Had my car serviced yesterday and had whiteline sway bars installed for both front and rear (they're fantastic but this is not the reason why i started this thread).
Tonight when i took it out for a drive, I started hearing this clunking metal-on-metal noise coming from the rear whenever i go through any pot holes big or small.
By the time I got home, i took out the torch and started inspecting the suspension and I just wanted to ask the following before i take the car back to the mechanic:
- Would I be wrong to assume that each sway bar comes with 4 bushes? 2 small, 2 larger ones?
- Would I be wrong to assume that the bushes are suppose to be the cushioning between the sway bar and the underbody of the car (so that 2 pieces of metal are not touching each other)
Referring to the diagram here http://www.the370z.com/members/markymark-albums-whiteline-sway-bars-picture11431-img-4507.jpg, I think i'm missing one of the bigger yellow bushes that has a metal ring wrapped around (with 2 holes on the ring so that 2 bolts can go through and secure it to the underbody).
Assuming that I am missing something - is it common for these things to just 'pop out' or is it really just a matter of tightening the bolts better?
HELP: Clunking noise from the back
Re: HELP: Clunking noise from the back
If I remember rightly I thought that the drop links and mounts are only supposed to be torqued up with the car on the ground...was this done at the workshop?
Might be worth backing everything off a turn, bouncing each corner and doing it up again.
If the whole yellow bush and the metal clip is missing then I would say that this is not normal and I have never heard of one just 'popping off'.
If the metal clip is still in place and there is no bush, then the bush could have failed. I have had this happen with a suspension arm bush before, it bush failed within 500 metres of driving
In either case, I would take it back to the garage.
NA6 B6T
Barbagallo Raceway : Long Track 67.394, Short Track 56.755
- zossy1
Not as familiar with the whiteline setup but I have just installed a FM/RB combination in my car.
Are the endlinks length-adjustable? If so, my money is on them being too long. Check for impact damage between the end of your swaybars and the back of your upper wishbones.
EDIT: In hindsight, I may be talking smack as I think this distance would remain fixed by the orientation of the endlinks attached to the lower wishbones... But might be worth checking anyway...
The sway bar is held to the body by two saddles with a fat yellow D-bush around the bar under each saddle. It would be impossible for a D-bush to disappear if they used the one supplied with the bar by Whiteline and it was assembled correctly.
- zossy1
manga_blue wrote:The sway bar is held to the body by two saddles with a fat yellow D-bush around the bar under each saddle. It would be impossible for a D-bush to disappear if they used the one supplied with the bar by Whiteline and it was assembled correctly.
I agree - that's why I can't imagine any half decent mechanic stuffing that part of the job up...
- mxfive95
It's possible that the end links were tightened whilst the car was up on the hoist. As the car is lowered down it puts strain on the bushes and they can tear apart.
Cheyne had a similar problem. Clicky viewtopic.php?f=30&t=45273
The bumper sticker on my porsche
"My other car is an mx5"
If that advice doesn't help take some photos it might make the issue clearer.
Thanks everyone,
I'm taking the car back to the mechanic this Sat morning to have it checked out.
Will keep everyone posted.
P.S. So frustrating that I can't drive the car out to feel more of the changes made by the sway bars
- zossy1
Users browsing this forum: No registered users and 338 guests
