running on 3 cyl after being jacked up
Si.G
Re: running on 3 cyl after being jacked up
Postby Si.G » Sun Mar 27, 2011 11:05 pm
I would look at the mis-fire as an independent issue and not relate it to the jacking.
I had a similar thing happen to me after working on the car, turned out that one of the cylinders had flooded, coupled with a very fouled plug that would not fire. Was totally un-related to the work I did. Maybe check the plugs
Si
NA6 B6T
Barbagallo Raceway : Long Track 67.394, Short Track 56.755
Guran
Vehicle: ND - 1.5
Postby Guran » Mon Mar 28, 2011 8:11 am
Check your plug leads. 8)
