Gday,
I had a strange thing happen today. After spending the whole afternoon replacing shocks and balljoints in my NA6, i went for a test drive, and for the first minute it was running on 3 cylinders. It didn't take long to go away.
The car spent a few hours with the front in the air, then a few hours with the rear in the air.
The only cause I can think of was that while jacked up some fluid must have run from somewhere to somewhere else, but I cant think of what it might be to make it run badly,
Otherwise i thought i may have knocked out a connector to something near the front shocker upper mounts, but I checked and it was all good.
Any thoughts?
ta
Paul
running on 3 cyl after being jacked up
Re: running on 3 cyl after being jacked up
I would look at the mis-fire as an independent issue and not relate it to the jacking.
I had a similar thing happen to me after working on the car, turned out that one of the cylinders had flooded, coupled with a very fouled plug that would not fire. Was totally un-related to the work I did. Maybe check the plugs
Si
Si
NA6 B6T
Barbagallo Raceway : Long Track 67.394, Short Track 56.755
- Guran
- Vehicle: ND - 1.5
Check your plug leads.
Users browsing this forum: No registered users and 124 guests
