At about 3200rpm in each gear i get this horrible metal sound and then goes away by 3400. Its as if there is somethign loose....
any ideas?
cheers
Terrible sound at 3200revs
- Uncle Arthur
- Dodgy Award Benefactor
- Location: Doesn't matter where I'm from-it's that your daughter is with me that's the biggest concern :D
Re: Terrible sound at 3200revs
can you describe the sound?
- de Bounce
Sounds like a guard or shield has cracked and at the correct revs it vibrates and makes the noise.
- Jeo
I had a similar problem but it was more like 2000-3000rpm and a grinding/knocking noise. Ended up being that the bolt that holds the pulley wheel on the water pump had seized.
Thanks Chaps,
Its as if something is grinding or like shaking a bag of metal...
ta
ta
yh, check all the heat shields and guards down the exhaust system for loose and rattling bits.
- 7Hazi
Check your cat - might be old and the internals have fallen apart (I have a similar problem on my car).
Users browsing this forum: No registered users and 64 guests
