MX5 Mania DYNO DAY 9th April
New South Wales and Canberra Events
Moderators: Andrew, -alex, miata, Midori
dave2221
Postby dave2221 » Mon Mar 21, 2011 1:10 pm
Found this on the MX5 Club NSW site.
I will be going, to get a baseline for my SE before i do any mods.
Details as per MX5 Club Site:
DYNO DAY at MX5 Mania
Details: Cost is $50 for three power runs and a print out.
A sausage sizzle lunch will be provided for Dyno Day entrants between 11.30 and 12pm. Runs will be held at 15 minute intervals starting at 9am through to 11.30am and from 12.00 till 2.30pm.
BOOKINGS are to be made directly to Ajay at MX5 Mania on 02 9482 3238.
Entry Fee to be paid directly to MX5 Mania on the day
BOOK direct to MX5 Mania
So i guess ill start a guest list
#1: Dave2221 (2004 SE - standard)
spacepants_fb
Re: MX5 Mania DYNO DAY 9th April
Postby spacepants_fb » Mon Mar 21, 2011 1:39 pm
I will be attending...to take photos if that's okay? :)
ForceMajeure
Postby ForceMajeure » Mon Mar 21, 2011 2:48 pm
I'm keen on this for my NB, probably not much to dyno but definitely could do with a tune. :)
Do they actually do a tune or is this just a competion to see who has the biggest.......KW's. :wink:
BadBong
Postby BadBong » Mon Mar 21, 2011 4:33 pm
ForceMajeure wrote:I'm keen on this for my NB, probably not much to dyno but definitely could do with a tune. :)
I was going to ask the same thing.
Other than finding out how much power I've lost since the car was new, would there be demo / chats on how to get those valuable Kw back?
dave2221
Postby dave2221 » Mon Mar 21, 2011 4:45 pm
dont know
but will be a good (and relativly cheap) way to discuss mods on your 5.....
ill be able to provide a baseline figure for the SE's (as mine is standard)
and those with mods can then compare.... :)
Midori
Postby Midori » Mon Mar 21, 2011 5:14 pm
First to register and selected a time that best suits my commitments s on the day. :lol:
At $50 the cost of the MX5 Mania dyno reading is not expensive and worth the money for curiosity value if nothing else. Remember you cannot rely on comparative results from different dynos. :shock:
MX5 Mania are moving to new premise at Unit 8/827 Old Northern Road Dural that is part of an industrial complex behind McDonalds. Check the venue as it could be held at Dural and not in current Hornsby Heights location. :?
HIC-45S
Postby HIC-45S » Tue Mar 22, 2011 11:44 am
This question will probably result in laughter at my expense, but it would be safe assume that Mania would have a 2WD dyno? Pretty keen to see what the Subaru can do, but it isn't going to work very well without a 4WD dyno :lol:
スカイライン ECR33 GTS25-t SII
"We produced with Spartan air"
dave2221
Postby dave2221 » Tue Mar 22, 2011 11:54 am
Booked...
Midori
Postby Midori » Tue Mar 22, 2011 1:55 pm
HIC-45S wrote:This question will probably result in laughter at my expense, but it would be safe assume that Mania would have a 2WD dyno? Pretty keen to see what the Subaru can do, but it isn't going to work very well without a 4WD dyno :lol:
To get an approximation of your KWs is really simple on a 2WD dyno. :?:
Ask David to reverse the Subaru onto his Dyno for the first reading of your rear wheels then drive on and take a reading from front wheels. :roll: Add the two readings together and divide by 2. 8) That way, if you can get a reading, you will know what your car was capable of before it went through the brick wall at the back of MX5 Mania and underwent a rebuild as a restoration project. :wink:
HIC-45S
Postby HIC-45S » Tue Mar 22, 2011 3:31 pm
I don't think the Subie will go through a wall, the centre diff is an open type so I'm going to guess it's just going to spin what ever wheels don't have weight on them :lol:
psquire45
Postby psquire45 » Wed Mar 23, 2011 3:21 pm
SWWWWEEEET ! thats jsut around the corner.... there goes all my cash :mrgreen:
1998 NB MX5, AVO turbo kit, Adaptronic plug'n'play, RX8 440cc injectors, Fm Brace, DBA cross drilled brakes, cusco rollbar Pedders springs
HIC-45S
Postby HIC-45S » Thu Mar 24, 2011 9:33 am
I did a little research into it when I went to a SAU dyno day at Unigroup (also a 2WD dyno). Dropping the front shafts (apparently) doesn't change the centre diff trying to transfer the power down the path of least resistance, so it will only work if I lock the centre diff in some way (solid diff for 2WD conversion / LSD).
TL;DR - AFAIK it's too hard and expensive to do on a factory standard Liberty that I only use as a daily :lol:
bjones
Postby bjones » Thu Mar 24, 2011 1:59 pm
Hey Im oncall as usual but might have to make a showing....lets put all these doubting thomas's to bed well and truely :evil:
BJ
Playing with BOOST will smoke your tyres!!!
NO LONGER MINE sob sob
Charlie Brown
Postby Charlie Brown » Thu Mar 24, 2011 4:25 pm
No tune involved just a run on the dyno so you can see how much, or little, your car's making.
Sorry I won't be there this time, I'll be in Paris 8)
Guran
Vehicle: ND - 1.5
Postby Guran » Thu Mar 24, 2011 6:47 pm
Charlie Brown wrote:Sorry I won't be there this time, I'll be in Paris 8)
Awwww. Diddums. Life's tough for some. :P :lol:
Users browsing this forum: No registered users and 89 guests
