Just discovered where my water was going
- snshami
Hi, I just discovered the cause of my disappearing water. The top tank of my radiator has a pin sized leak.
Is it hard to change the radiator. How long would it take an amateur?
Anyone got a new one they want to sell?
1997 NA8 Neo Green - Limited Edition
- snshami
Re: Just discovered where my water was going
Borked wrote:Give yourself the weekend with a few mates around, include a BBQ and a slab or five, pending numbers, and have a good weekend
Now you are scaring me
- snshami
One more question I had in my ever probing mind
Is it safe for me to continue driving for the next few days with this smallish leak or is it likely to become a catastrophic failure soon.
- zossy1
Easy peasy.
Assuming you have AC, you have 2 fans to disconnect and remove.
Remove your intake to make the job easier.
Drop the lower hose and drain coolant. Remove the bracket holding the metal portion of the lower hose to the chassis rail to give you more room.
Remove top hose and coolant overflow tube.
Then remove the four 10mm bolts securing the radiator to the mounting brackets and carefully slide the radiator out - left side first - it should then come straight out the top.
Install in reverse, fill and burp cooling system, win.
An hour should kill it.
- zossy1
snshami wrote:One more question I had in my ever probing mindIs it safe for me to continue driving for the next few days with this smallish leak or is it likely to become a catastrophic failure soon.
Oh one thing I forgot - obviously you will have to swap the fans over. Removing them before you pull the rad will make the extraction much easier.
I would not drive it until it is fixed - certainly not very far. But that's just me.
- Jeo
With little mechanical experience, I changed mine in about 2hrs. It's fairly straight forward.
- snshami
Thanks everyone. Why can't I remove the fans after I have taken the radiator out. Is there something preventing me doing that.
Also do I need to jack the car up at the front for access underneath?
And what type should I buy. There seem to be four broad choices for the standard size radiator. Mazda OEM for over $600. Chinese including Ebay for around $200, Indonesian ADR brand ones in the $200s and Australia made Natrad for $248. What are your experiences with these.
To save money, Take the rad to a repairers for a new top tank.
As for how hard the job is, I can't remember as it was so easy and straight forward. Pretty sure the rad came out with fans on. I have an NA
Graham
- Caffeine
Just keep it topped up and you should be fine, obviously keep an eye on it to see if the leak gets more dramatic.
Replacement should take around 1/2 an hour of work, plus 1/2 an hour waiting for things to drain etc
I did a coolant system flush on mine when I replaced the radiator (same reason, pin sized hole in the top tank), that added an extra 45 minutes...
- snshami
I had never thought about getting the existing radiator repaired. Apparently a new top tank would cost $140 while a new one would cost $240. The 140 would only involve changing the top tank not the bottom one. According to the person I spoke to the lower tanks are never a problem..
Are there any disadvantages of repairing an existing radiator over getting a new one.
Not if the rest of the rad is OK, They usually crack opposite where the water hose joins. Had mine done about 3 years ago, still fine
Graham
- zossy1
snshami wrote:Thanks everyone. Why can't I remove the fans after I have taken the radiator out. Is there something preventing me doing that.
Also do I need to jack the car up at the front...
Taking the fans off makes it easier to slide it out. It gives you more space to maneuver the radiator out and slide it out of the mounts.
Once you start the job you will see what I mean
Shouldn't need to jack the car up but doing so, and removing the lower tray, will definitely make it easier to access the lower hose.
I thought snashami worked in the auto industry- don't the engineers know these things. All these questions are just absolute basic stuff. Some of us just owned bombs when young and had to do repair things and picked up some info on the journey- I think very hard these days as to whether it is worth the hassle of diy and technology has moved on. Anyone thinking about DIY has to buy a repair manual and do some reading and knowledge will never come overnight.
OEM is generally the safest route for parts but maybe a reputable maker does a aftermarket unit. OEM units are designed for the car and they work and everything will bolt up correctly etc. The MX5 factory is not far from Doreen and they are a source of info and pricing etc.
If a radiator gives a prob them take it to a repairer and ask questions of the experts and get quotes etc. For many just paying to get something done is best esp if you do not have the tools the facilities or basic knowledge. Even changing a radiator can end up with a system which is not refilled correctly and then overheats which can be disastrous- but a manual like Haynes should give pointers.
viewtopic.php?f=76&t=37363
not certain if the links are still active.
the Mazda manual covers a lot more than a Haynes etc, although it often says you need SSTs (Specialised Service Tools)
often you can make do with standard tools, might just take you a few more minutes.
- snshami
Mr Morlock wrote:I thought snashami worked in the auto industry- don't the engineers know these things. All these questions are just absolute basic stuff. Some of us just owned bombs when young and had to do repair things and picked up some info on the journey- I think very hard these days as to whether it is worth the hassle of diy and technology has moved on. Anyone thinking about DIY has to buy a repair manual and do some reading and knowledge will never come overnight.
Mr Morlock, we don't have to converse in 3rd person. You can address me directly
Yes I do work in the auto industry actually for an OEM manufacturer in Product Development. As you can imagine the field of automobiles is extremely broad. Just because you can design and develop something doesn't mean you can necessarily repair something. Also different cars are different. I once changed a radiator on a Mercedes but you can literally have a part under a Mercedes while an MX-5 is far lower. For instance I can't squeeze my head under most parts of the MX-5 even while it is sideways. On the Mercedes I could. I don't have ramps or stands so access becomes an issue, hence my question. You can then hopefully understand where the rest of my questions are coming from without me having to provide an in-depth analysis of each.
Basically I was doing a cost benefit analysis of getting the work done by someone else vs doing it myself and using the money saved to buy some more equipment that I don't presently have.
I am also a cautious person so I like arming myself with more information rather than less.
