Volt Gauge
Sailor
Volt Gauge
Postby Sailor » Fri Aug 21, 2009 7:34 pm
Robbo wrote:I am about to install a volt gauge in my NB. I hope someone can assist with directions as to the best way/easiest way and where to wire it up to. I know the wires will have to be joined into the wiring system somewhere "BUT WHERE!" :roll: :idea:
Hope someone can help.
Gotta ask....Why?
Seems like just another bit of clutter
Rob
dave2221
Re: Volt Gauge
Postby dave2221 » Fri Mar 11, 2011 11:31 am
THREAD RESURECTION!
OK, So where do you put aftermarket guages LEGALLY? Specifically on a NB8B
I know i can go down the road of a dual pod cluster on my a-piller, but that will attract any unwanted attention from the fuzz.
I dont want to take my stereo out and put in a single din unit (with the 3 guages underneath)
has anyone stuck it in front of the gear shifter, where your cigarette lighter goes?
if i must, i might make one out of Carbon Fibre, as i want oil and boost pressure (SE model)
i also want to retain the factory cigarette lighter too, so that will occupy that space too!
Robbo
Vehicle: 10AE
Re: Volt Gauge
Postby Robbo » Fri Mar 11, 2011 2:35 pm
Hi dave2221,
I have put gauges in my NB8A 10AE model. Under my radio was a DIN space. I replaced that space with a 3 gauge holder I obtained from www.mx5parts.co.uk look under (interior/instruments) you can get a 2 gauge holder or a 3 gauge holder. They fit like a glove, but there is a bit of mucking about to get the DIN unit out. :NB8A:
dave2221
Re: Volt Gauge
Postby dave2221 » Fri Mar 11, 2011 2:43 pm
Robbo wrote:Hi dave2221,
I have put gauges in my NB8A 10AE model. Under my radio was a DIN space. I replaced that space with a 3 gauge holder I obtained from http://www.mx5parts.co.uk look under (interior/instruments) you can get a 2 gauge holder or a 3 gauge holder. They fit like a glove, but there is a bit of mucking about to get the DIN unit out. :NB8A:
thanks robbo, but i have the 6 stacker model, so i dont have a spare din unit.
i have been reading up on the NSW laws, and i think i can get at least 1 guage pod on the A-pillar.
The basic rules are as follows...
1. must not be in the line of vision
2. must not be able to hit your head.
i think one down low would be fine, as its pretty much ipossible to get your head down there, and it wouldnt be effecting your view of the road.
as for a double gauge cup, i think the 2nd gauge would fall under point 2..... as our pillars are pretty close to us.
Thoughts?
Users browsing this forum: No registered users and 60 guests
